TrayProdder
Windows Explorer in XP gets two new features
Windows Explorer is a great little program. Millions use it, few have any complaints. But unless you've moved to Vista, there are things you can't do in Windows Explorer:
Checkboxes: you can't get a checkbox column to select files with. So you either select one file at a time, use a selection rectangle to "lasso" some adjoining files or you multi-select. Multi-select is when you tediously hold down the Ctrl key and then click one file at time to expand the selection. Until you accidentally lift the Ctrl finger and have to start all over again. Tedious.
Fullrowselect: you can't get the selection color to encompass all columns in the file list. Which would have been helpful if your selection criteria depends on, for instance, the file date.
With TrayProdder, these two features are no longer missing.
Website
Using TrayProdderOrginal post by howtogeek
