Posted December 21, 200816 yr a friend of mine wants yahoo set as default home page after xp installed, nlite doesn't have yahoo optionso i edited the last session & winnt.sif as below: however when internet explorer is opened msn.com is openedi tried www.yahoo.com & also http://www.yahoo.com/ , is there something missing to make yahoo the default?thank you & happy holidays to allhere is nlite last session: it is same as if you selected google, i just edited it to yahoo & saved[Tweaks]Desktop-Desktop icons size-48Desktop-Internet Explorer icon-ShowDesktop-My Computer icon-ShowDesktop-My Documents icon-ShowDesktop-Recycle Bin icon-ShowExplorer-Change Windows Explorer folder view-IconsInternet Explorer-Disable Download Complete notificationInternet Explorer-Keep IE URL-History for-0 DaysInternet Explorer-Set Homepage-http://www.yahoo.com/ <<<<<<<<<< edited hereInternet Explorer-Set Internet Explorer to accept 10 connects at a timeStart Menu-Clear most recently opened documents list on logoffStart Menu-Disable Highlight newly installed programsStart Menu-Number of programs on Start menu-0Start Menu-Reduce popup delayTaskbar-Disable Language-BarTaskbar-Disable Windows Tour popupWindows Media Player-Accept Privacy StatementWindows Media Player-Disable starting with Media Guidehere is winnt.sif: it is same as if you selected google, i just edited it to yahoo & saved Home_Page=http://www.yahoo.com/ <<<<<<<<<< edited here Edited December 21, 200816 yr by freeheart4sale
December 22, 200816 yr Author i added the branding to the winnt.sif, i loaded the nlite last session with the homepage set to yahoo & added the branding, but either google or msn opens with internet explorer, please help! am i missing something? thanks (if i choose google, it works, but not yahoo) yahoo doesn't open even on 2nd,3rd,4th trynlite last session:Internet Explorer-Set Homepage-www.yahoo.comwinnt.sif :[branding]BrandIEUsingUnattended=YesHome_Page=http://www.yahoo.com/
April 26, 200915 yr I sometimes use the $OEM$ folder to set a default website.In the cmdlines.txt i set the following command:[Commands]"REGEDIT /S WebsiteDefault.reg"Put this in the reg file:Windows Registry Editor Version 5.00;Changes Main Web Page to Planet.nl[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]"Start Page"="http://www.yahoo.com"WebsiteDefault.reg file hase to be in the same folder as the cmdlines.txt Edited April 26, 200915 yr by UtCollector
