Posted December 22, 200816 yr Simple to use Serbian-English, English-Serbian Dictionary with pronunciation and it's free. Licence: FreewareAuthor of the dictionary: Predrag VujicAdd-On: 6700E5A949215D069E8AC1D0B54FEEC5 1.71 MB Edited February 22, 200916 yr by Kelsenellenelvian
December 29, 200816 yr The idea to make this Add-On is from N1K's Topic here http://www.wincert.net/forum/index.php?sho...amp;#entry39557Add-On: 99656900D0D520B488E951431785C4FD 152KB Edited January 19, 200916 yr by DennyMK
December 29, 200816 yr This was in my to do list, thanks for your work You are welcome @MrNxDmX Edited January 6, 200916 yr by DennyMK
December 30, 200816 yr Cathy 2.28 CatalogCathy descriptionA useful and reliable disk cataloging applicationCathy is a useful and reliable disk cataloging application that you can use to index files stored on removable media (CD-ROMs, LS120, Iomega Zip and Jaz disks, or even diskettes) and create searchable catalogs that can be used without having to insert the CD.Searching capabilities are based on file name, date and size and special support for mp3 file searches. Additional features include filtering options, duplicate search The program is easy to use, allows searching across multiple catalogs in a matter of seconds. Standalone, no install needed.See screenshots hereLicence: FreewareAuthor of the program: Robert VasicekAdd-On: 4E6E395FE1D7C4DFE2230B3F718397D8 162KB Edited January 19, 200916 yr by DennyMK
December 30, 200816 yr Download link not working..Try again, I've personally tested 3 times and it worked (just need some time to start ). Edited December 30, 200816 yr by DennyMK
January 1, 200916 yr snakecracker: Link works for me, be sure that scripts are enabled in your browser (in case u're using firefox and noscript) DennyMK: This program seems doing a good job buddy, thanks for share
January 1, 200916 yr @MrNxDmX:I'm dedicated to WinCert, and I wanna share my stuff with members. Off-Topic Comment(Click to Show) Anyway, I'm still far away from your knowledge about add-on making, and will like to learn from the best add-on makers :thumbsup_anim: .The greatest add-on maker I know yet and my teacher in add-on making is @wolfcall.No offence, I think you are a great add-on maker too :thumbsup_anim: [Close]
January 6, 200916 yr Desk Space version 1.5.54 Expand your desktop spaceDeskSpace significantly increases your desktop space, allowing you to work and play on multiple desktops.With DeskSpace you can organize your programs and icons on multiple 3D desktops, and quickly switch between these desktops using the mouse and keyboard.DeskSpace: 3D Virtual Desktop.Eliminate desktop clutterDon't have enough space to fit all your programs and icons on a single desktop? DeskSpace gives you more room to store everything you need for your day-to-day work and play.DeskSpace eliminates desktop clutter by giving you the ability to store your windows and desktop icons across multiple desktops.DeskSpace: 3D Virtual Desktop.Increase your effiecencyCan't find the application you want because your screen is full of windows? DeskSpace gives you the ability to place your applications on separate desktops and then quickly switch between desktops to find the application you need.With DeskSpace, you can find the application you want when you want it.Get organizedDoes limited desktop space make it hard for you to stay organized? DeskSpace helps you organize your work flow, allowing you use a separate desktop for each of your tasks. With DeskSpace, you could have a one desktop for web browsing, a separate desktop for word processing, and another desktop for spreadsheets.DeskSpace helps you to stay organized by giving you the ability to use different desktops for different tasks.Features and benefitsDeskSpace dramatically enhances your desktop experience, allowing you to: * Work and play on multiple desktops. * Display multiple desktops in stunning 3D. * Quickly switch between desktops using the mouse and keyboard. * Drag windows between desktops by moving them to the sides of the screen. * Display desktops in 3D on multiple monitors. * Configure the hot keys and mouse buttons used to switch between desktops, and how DeskSpace displays and manages desktop. * Use DeskSpace in multiple languages.System requirementsThe minimum system requirements for DeskSpace are: * Windows XP, Windows Vista, or Windows Vista x64. * 800 Mhz CPU. * 256 MB RAM. * 16 MB DirectX 8.1 compatible video card *.* Minimum ATI Radeon 7200 or nVidia GeForce 2 required. Video cards based on the nVidia TNT2, ATI Rage Pro/128, and Intel Extreme chipsets may work, but are not supported.Screenshots: Video: Add-On: 5AF20696098E53402ECAB715B6F0290B 2.73MBWARNING: This program is free only 14 days and does not contain any cracked files or serials, you register the program yourself on first run.Off-Topic Comment(Click to Show) Sorry for missunderstanding.And yeah, I wanted to share my present of retail version, not meaning any harm, but by the rules I needed to remove the retail version and post the trial one.[Close] Edited January 7, 200916 yr by DennyMK
January 7, 200916 yr DeskSpace generally costs U$25-, is this a cracked/hacked version or ??You say that 'no serial is needed'.
January 7, 200916 yr Link disabled untill I get more info...It's Retail version, not cracked one, if you extract the files can see that.
January 7, 200916 yr Topic unlocked by the request of the author.Download link is changed with the trial version of this addon.
January 7, 200916 yr Thanks N1K Off-Topic Comment(Click to Show) Ex YU Respect :thumbsup_anim:[Close] :thumbsup_anim: :thumbsup_anim: Edited January 7, 200916 yr by DennyMK
January 7, 200916 yr Its still stealing/closedThis isn't a "stealing" like you say. I got the retail program as a present and I wanted to share with WinCert members.Off-Topic Comment(Click to Show) Please, stop judging before you ask, what's the reason[Close]
January 7, 200916 yr This isn't a "stealing" like you say. I got the retail program as a present and I wanted to share with WinCert members.Off-Topic Comment(Click to Show) Please, stop judging before you ask, what's the reason[Close]Denny, don't attack my moderators in who I have full trust. They acted as they should to protect interest of this forum. One more word of this and I'll close this topic.
