dougiefresh Posted January 31, 2009 Posted January 31, 2009 Quote from homepage:This is a virtual floppy drive for Windows NT / 2000 / XP (works also on 2003, it seems).Note !!! This version works only on 32 bit systems !!!You can mount a floppy image file as a virtual floppy drive and directly access the contents -- view, edit, rename, delete or create files on a virtual floppy, format a virtual floppy, launch a program on a virtual floppy... almost anything you can do with a real floppy.Add-On installs the driver, as well as creates associations for the control program, and adds a Control Panel applet for ease of access.NOTE: This add-on works with Windows 7 32-bit OS!!!! Doesn't require it to be right-clicked on and run as Admin, as the executable has been modified to make it mandatory!FileName: Doug_VFloppy_AddOn_v2.0.rarFile Size: 115kbMD5: F221ECADA16A9297B8D35AE58D436CE8Changelog:v1.0b1 = Initial Releasev1.0b2 = Added DefaultInstall and DefaultUninstall, turned on shell extensionsv1.1 = Rewrote INF so that installation happens through RUNONCE.v2.0 = Modified executable to run as admin, added it to the Hardware group in the Control Panel. Quote
bjfrog Posted February 6, 2009 Posted February 6, 2009 niice, i installed a new 1.44drive on Vista Quote
tinad Posted August 3, 2009 Posted August 3, 2009 Corrected invalid link....Thanks for sharing the addon, but I'm getting a Comcast 404 error:"Sorry, the page you were looking for could not be found." Quote
dougiefresh Posted August 5, 2009 Author Posted August 5, 2009 Edited link again.... Sorry about that! Quote
v51d Posted March 12, 2011 Posted March 12, 2011 el server dice que el archivo no existe, podrias subirlo otravez porfa :welcome: Quote
dougiefresh Posted October 10, 2011 Author Posted October 10, 2011 I've modified executable to require it to be run as an Adminstrator. Incidentally, this also makes it work 100% of the time with Windows 7 when run as an Adminstrator!I also added it to the Hardware group in the Control Panel, making it easier to navigate to when using the Categories setting in the Control Panel.el server dice que el archivo no existe, podrias subirlo otravez porfa :welcome:Link has been updated. Sorry about the late response! Quote
