Posted December 29, 200618 yr QueVistaLS v4 by Virus956AddOn uses different Wallpaper and ShellStyle than the original (Its modded) Installs LS Patch and Vista Start (Vista Start button addon) and adds shortcuts under Start->All Programs->UtilitiesMD5: 61F880A204F1C317A2115E58709F928DSize: 2.32 MBWebsite: http://www.deviantart.com/deviation/48376173
February 9, 200718 yr This is nice shell, but I must point on some graphical errors, they can be spotted on screenshoots in the first post. You can noticed small dash on the left side of the frame, show on picture below. Never the less this is one of the best Vista shells.
March 7, 200718 yr Hey,Is is possible to remove the text "Log Off" and "Shut Down" from a traditional Windows theme as you've done with this release?Thanks.laze.
March 7, 200718 yr Author The LS patch works on ALL themes not just for this one http://www.wincert.net/forum/index.php?showtopic=278
September 26, 200717 yr Please Redownload AddOn I updated to v1.1 fixed error in the first onewhere is the addon
September 26, 200717 yr Installs LS Patch and Vista Start (Vista Start button addon)Does the Vista start you mean is ViStart buld 2502?If Not, can I install it together with this addon?
September 26, 200717 yr Author That is not ViStart its a vista start orb for XP and it does not start on 1st login, you have to enable it.
