February 2, 200916 yr seems a nice tool have alot of function thx i will test it soon and problems i will feedback
February 3, 200916 yr hi rs90 can you add taskkill parameter to your progand this work with 8.3 file format
February 3, 200916 yr :welcome6ld: rs90 really useful tool.I have one question : does it support duplicate files or files with the same name?when I did a winamp true addon I used some batch files to find files having the same name and renaming accordingly. does your tool do the same? if so then bye bye my dear "batches" keep up the good work :thumbsup_anim:
February 4, 200916 yr Thank you for your great Feedback. :thumbsup_anim: @ monaYes i can add the taskkill parameter, but i must inform me about this parameter first.The name of the *.cab and *.inf File are in the 8.3 format, the names of File's in the *.cab archiv must not be in the 8.3 format.ok sRunPreSetupCommands =Close.Program:1 ;<- The ":1" Flag Hides the taskkill.exe CMD window (does not need to be in section name);Closes program executable if running before uninstall[Close.Program]TASKKILL /F /IM Program.exe;for XP Home compatibility useTSKILL Program ;<- tskill fails if you add the file extention (bad example: tskill program.exe)or see this post made by rick taskkkil
February 6, 200916 yr Hi,why must be the entry for XP Home without File Extension? i think taskkill.exe not included with XP Home
February 6, 200916 yr TSKILL is quite superior to taskkill.exeIt is much simpler and quicker to use.No swithes and extensions needed, just the "tskill program"
February 7, 200916 yr great tool .... thought I would try it on WinAVI 7.7, adding HelixSDK to program files ... worked perfect ... very user friendly.many thanks :thumbsup_anim:
February 7, 200916 yr hi rs90 1.if you can add other key to program like thisOff-Topic Comment(Click to Show) HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\%AppName%","Comments",0,"Easy Duplicate Finder"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\%AppName%","DisplayIcon",0,"%16422%\Easy Duplicate Finder\EasyDuplicate.exe"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\%AppName%","NoModify",0x00010001,01,00,00,00HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\%AppName%","NoRepair",0x00010001,01,00,00,00HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\%AppName%","Publisher",0,"Easy Duplicate Finder"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\%AppName%","URLInfoAbout",0,"http://www.wincert.net/forum/index.php"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\%AppName%","URLUpdateInfo",0,"http://www.wincert.net/forum/index.php"[Close]and sometimes dont need basic true addon so dont need regkey in program (only need to add manually from captured registry file) so if you can addbutton for cheack uncheak add registy from Inf Addon Makerand if you can add BeginPrompt for manually installation like kel_uberpackand i think found two bug in your program1.when create addon in the inf file in a CopyFiles and DelFiles section found free space betwen RootOrdner1.Copy, UnterOrdner1.Copywhen test with fgcba get alot of error so if remove space from RootOrdner1.Copy,UnterOrdner1.Copy dont get problem 2.In shortcut section please see this videodddd.7z
February 7, 200916 yr this is my inf file from icofx1.1.7zand about bug 2this video noting from Startmenu/Desktopis a from start menu shortcutwhen i want create shortcut in a C:\Documents and Settings\All Users\Start Menufrom EasyDuplicate.exe with name Easy Duplicate Finderthen i want create shortcut in a C:\Documents and Settings\All Users\Start Menu\Programs\Easy Duplicate Finderfrom EasyDuplicate.exe and Help.url with name Easy Duplicate Finder and Help on the Web in a folder:Easy Duplicate Finderonly allow create one shortcutplease see again video thanks Edited February 7, 200916 yr by mona
February 8, 200916 yr Hi rs90, this is a good job. Is it possible that I make a French translation of the ini file? With your agreement I attach to your topic.Thx
