Posted December 30, 200618 yr 12/30/2006Updates:Shoutbox module has been upgraded from v1.0 to v1.1New release of Shoutbox module has some new features and improvements. This version isn't visible by default, so you'll have to click the "Shoutbox" link in the navigation pane of the forum and go to "my prefs". From there you can adjust the behaviour of the Shoutbox just the way you want..If you have any issues with this module, please reply in this topic..Thx..
December 30, 200618 yr I was about to say its not working... But I checked Global Shoutbox and its back
December 30, 200618 yr Author I've just made the shoutbox visible on all forum pages by default.. :thumb_yello:
December 31, 200618 yr hey i need that update man can u post it on my forums for me to u[grade mine and my buddy's?
December 31, 200618 yr Author ZG WestSide said: hey i need that update man can u post it on my forums for me to u[grade mine and my buddy's?I saw that you've fixed it :thumb_yello:
January 2, 200718 yr Author 12/30/2006Updates:Shoutbox module has been upgraded from v1.1 to v1.1.1Changelog:v1.1.1 Fixed 'Enter Key' issue that wouldn't allow other input fields (mainly textareas') to be used properly to enter new lines.Fixed '[DATE] Guest -' issue where this would appear several times when doing a new install on the Shoutbox.Fixed issue where Global Shoutbox wasn't displayed (turned on) by default, for all members.Fixed issue where Announcement wouldn't show up in the Global Shoutbox.Fixed issue where 'My Prefs' button wasn't displayed in the Global Shoutbox.Fixed bug when deleting a moderator from the Admin CP, wouldn't delete it but just go to the Overview page for the Shoutbox.------------------If you have any issues with this mod please reply in this topic..Thx.
January 2, 200718 yr Working fine for me so far. Glad to see its being worked on though. Just in case
January 7, 200718 yr Author 01/07/2006Updates:Shoutbox module has been upgraded from v1.1.1 to v1.1.2
January 9, 200718 yr @ N1KDo you know that this is the 1st forum I've visited yet use the shout box !?It keeps forum more a live
