  • Replies 83
  • Views 69.3k
Hey guys, check it out :D
http://www.google.ca/search?hl=en&q=ad...+menu&meta=
Edit: I've just checked into some of this and it looks rather... weird.
A person has taken the regtweak, and modified the beginning piece of it and taken our names out and said it was by him.
;"Recycle Bin in Start Menu" RegTweak by Arnab
;Adds Recycle Bin shortcut to Start Menu
[HKEY_CLASSES_ROOT\CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}]
@="@%SystemRoot%\\system32\\SHELL32.dll,-8964"
"InfoTip"="@%SystemRoot%\\system32\\SHELL32.dll,-22915"
[HKEY_CLASSES_ROOT\CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\DefaultIcon]
@="%SystemRoot%\\system32\\shell32.dll,32"
[HKEY_CLASSES_ROOT\CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\InProcServer32]
@=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,\
00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,00,68,00,\
64,00,6f,00,63,00,76,00,77,00,2e,00,64,00,6c,00,6c,00,00,00
"ThreadingModel"="Apartment"
[HKEY_CLASSES_ROOT\CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\Instance]
"CLSID"="{3f454f0e-42ae-4d7c-8ea3-328250d6e272}"
[HKEY_CLASSES_ROOT\CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\Instance\InitPropertyBag]
"CLSID"="{13709620-C279-11CE-A49E-444553540000}"
"method"="ShellExecute"
"Command"="@%SystemRoot%\\system32\\SHELL32.dll,-8964"
"Param1"="::{645FF040-5081-101B-9F08-00AA002F954E}"
[HKEY_CLASSES_ROOT\CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\shellex\ContextMenuHandlers\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}]
[HKEY_CLASSES_ROOT\CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\shellex\MayChangeDefaultMenu]
[HKEY_CLASSES_ROOT\CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\ShellFolder]
"Attributes"=dword:00000000
;Adds "[ ] Recycle Bin" Check Box to Strat Menu Properties (Show/Hide Start Menu Item)
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartMenu\StartPanel\ShowOEMLink]
"Type"="checkbox"
"Text"="@%SystemRoot%\\system32\\SHELL32.dll,-8964"
"HKeyRoot"=dword:80000001
"RegPath"="Software\\Microsoft\\Windows\\CurrentVersion\\Explorer\\Advanced"
"ValueName"="Start_ShowOEMLink"
"CheckedValue"=dword:00000001
"UncheckedValue"=dword:00000000
"DefaultValue"=dword:00000001
"NoOEMLinkInstalled"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartMenu\StartPanel\ShowOEMLink\Policy\NoOEMLinkInstalled]
"RegKey"="Software\\Microsoft\\Windows\\CurrentVersion\\Explorer\\StartMenu\\StartPanel\\ShowOEMLink"
;Adds "[ ] Show Recycle Bin icon on desktop" to Folder Options (Show/Hide Recycle Bin)
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\RecycleBinOnDesktop]
"RegPath"="Software\\Microsoft\\Windows\\CurrentVersion\\Explorer\\HideDesktopIcons\\NewStartPanel"
"Text"="Show Recycle Bin icon on the desktop"
"Type"="checkbox"
"ValueName"="{645FF040-5081-101B-9F08-00AA002F954E}"
"CheckedValue"=dword:00000000
"UncheckedValue"=dword:00000001
"DefaultValue"=dword:00000000
I know I shouldn't really think of it this way, but come on.
I'm going to modify the original post to fix this hopefully.
Edited by prx984
Nice work lads, smooth. I downloaded it though, and when I click it it just opens up C:\ , not the recycle bin. When I try to open the registry call (ie {645FF040-5081-101B-9F08-00AA002F954E} ) it does the same too..!
Any ideas anyone? As far as I'm aware, my recycle bin is actually at E:\Recycled if that's any help...
Thanks for any advice,
rambo8521.
downloaded the recyclermd file, rtclick, intsall, rebooted.
not workin in my vista ultimate. checkd in startmenu props>customize, the recycle bin option was checked. stil dznt appear !?
wat did i do wrong !?
You used it on Vista. This reg tweak is for XP only right now. I haven't had the time to try and make it work for Vista, but maybe theres someone who can convert it to Vista for you.
:tumbleweed:
