DVD Shrink 3.2.0.15
DVD Shrink is a freeware tool for fitting a DVD-Video disc on a single DVD-R.
DVD Shrink will also burn your backup DVD, if you have installed the latest version of Nero. If you already possess alternative burning software and prefer to stick with it, then you can still use DVD Shrink. The output from DVD Shrink can be saved as files on your hard drive, which you can then burn with software of your choice.
Licence: Freeware
OS: Windows (All Versions)
Author: http://www.dvdshrink.org/
Add-On:
md5.png 02049e5767d8d73d425bc89c56948e80
size.png 1.04 MB
