Posted February 11, 200916 yr PowerISO 4.3PowerISO is a powerful image processing and file compression tool, which allows you to create, extract, compress, edit and convert ISO/BIN image files, and mount these files with internal virtual drive. And most of all, the compressed files can be used directly without decompressing. Support almost all CD/DVD-ROM image file formats (ISO, BIN, NRG, DAA and so on). Main Features: *Support almost all CD/DVD-ROM image file formats(ISO, BIN, NRG, CDI, DAA and so on). Note: DAA(Direct-Access-Archive) is an advanced format for image file, which supports some advanced features, such as compression, password protection, and splitting to multiple volumes. It can be handled directly just like other formats, such as ISO, BIN, ... * Open and extract ISO File. * Create ISO file from hard disk files or CD/DVD-ROM. * Edit an existing ISO file directly. * Convert image files between ISO/BIN and other formats. PowerISO can convert almost all image file formats to standard ISO format file. * Make bootable ISO file, get boot information from bootable ISO file. * Make floppy disk image file. * Optimize files to save disk space while saving ISO file. * Mount ISO file with internal virtual drive. You don't need install any other virtual drive software. * Can be used easily. PowerISO supports shell integration, context menu, drag and drop, clipboard copy paste... New Features: * Supports UIF file. * Supports Windows Vista. * Supports on-the-fly burning. * Supports Apple DMG file. * Supports multiple languages. * Supports command-line parameters. Licence: Demo - you can not create or edit image files greater than 300MBOS: Windows (All Versions)Released: Nov 6, 2008Author: http://www.poweriso.comAdd-On:0135eb77ee57d679979ec740675c6332 1.09 MB Edited February 11, 200916 yr by zEn
April 4, 200916 yr Managed To get Power iso, As mediafire reported the file unavailable!is there any way to incorperate a serial into power iso!regardsmuffy! (mike)
May 9, 200915 yr Managed To get Power iso, As mediafire reported the file unavailable!is there any way to incorperate a serial into power iso!regardsmuffy! (mike)Start the regedit tool and go to HKEY_Current_User->Software->PowerIso-> export regvalues and the entry USER(REG_BINARY) is your serial. You can integrate this at next install.Greetz
