IP Tools 2.58
IP-Tools includes 19 utilities:
Local Info - examines the local host and shows info about processor, memory, Winsock data, etc
Connection Monitor - displays information about current TCP and UDP network connections
NetBIOS Info - gets NetBIOS information about network interfaces (local and remote computers)
NB Scanner - shared resources scanner
SNMP Scanner - scans network(s) for SNMP enabled devices
Name Scanner - scans all hostnames within a range of IP addresses
Port Scanner - scans network(s) for active TCP based services
UDP Scanner - scans network(s) for active UDP based services
Ping Scanner - pings a remote hosts over the network
Trace - traces the route to a remote host over the network
WhoIs - obtains information about a Internet host or domain name from the NIC (Network Information Center)
Finger - retrieves information about user from a remote host
LookUp - looks for domain names according to its IP address or an IP address from its domain name
GetTime - gets time from time servers (also it can set correct time on local system)
Telnet - telnet client
HTTP - HTTP client
IP-Monitor - shows network traffic in real time (as a set of charts)
Host Monitor - monitors up/down status of selected hosts.
Trap Watcher - allows you to receive and process SNMP Trap messages.
Features:
* Program allows multitask operation - You may use all utilities at the same time.
* Many utilities can obtain information from a single host, from all hosts within a range of IP addresses (ex. 195.128.74.1 - 195.130.200.5) or work with list of hosts and IP addresses.
* IP-Tools can save obtained information into text file or create cool HTML reports.
* Highly intuitive interface makes operation easy for users
* Easy Install / Upgrade / Uninstall program
* After registration you gain the right to use ALL future IP-Tools updates and releases, on the same OS platform, in the registered mode.
Released: December 12, 2008
License: Trial (21 days)
OS: Windows 98, ME, NT 4.0 (SP3), 2000, XP Professional, Windows Server 2003, Windows Vista or Server 2008
Author: KS-soft
Add-On:
md5.png df5e85f403d127581128b5be7f1efa66
size.png 1.51 MB
