Tarun Posted December 31, 2006 Posted December 31, 2006 (edited) Welcome to the Security Threats forum here on WinCert!This snippet of information comes from my own website, Lunarsoft. Consider this an introduction to Anti-Malware, PC Maintenance and what to do for help with HijackThis.Before you post your logs please go to this PC Cleanup page to clean your computer. This page is now in a wiki format to allow fast loads and easy to read guidelines for all users, no matter what your Internet speed is.Be sure to pick up the Anti-Malware Toolkit (*.exe installer) or Anti-Malware Toolkit (*.zip) so that you can get the programs you need to clean your computer!Follow all of the instructions and upon completion post your log here in the following format:Username - HijackThis Log #Should you have further problems you will be asked to do certain things such as running any/all of the applications again and then repost your log. In this case you would post a reply in your own thread with the new log.By omitting the running of the contents of the Anti-Malware package(s) when posting a log you risk wasting valuable time that could be spent assisting other users.Startup optimization is also included after all the spyware/adware has been cleaned from your system.Good luck!Tarun Edited May 17, 2010 by Tarun Quote
NIM Posted January 1, 2007 Posted January 1, 2007 Thx Tarun for the first topic in this forum.. :thumb_yello: Quote
Tarun Posted January 1, 2007 Author Posted January 1, 2007 You can pin this so people can refer to it too. ;P Quote
PorPorMe Posted May 25, 2008 Posted May 25, 2008 I am going to do exactly that. I have a full time suite running along with a secondary monitoring program. I run scans with other programs at least every couple of days. I thought all was well. I always pick up Adware, no worries there but eTrust PestControl picked up a low level Trojan. To make a long story short- I ran 6 different programs all set to deep scan and each one picked up something, even the last one. It was mostly low level stuff but there was 1 high level virus. I "should" be clean now. I'm going to run the test anyway. I feel a bit shell shocked. :angry: :censored: :omg: Quote
NIM Posted May 25, 2008 Posted May 25, 2008 I can't understand how come that so many of you guys have malware, spyware or adware issues. I never had problems with any of those web parasites. I'm using only NOD32 along with Windows Defender.On XP, while Windows Defender still wasn't available, I haven't used anything for spyware protection.I personally don't trust those anti-spyware apps, not one of them, Those applications can help you in some cases, but they also like to "make up" adware on your PC. Quote
PorPorMe Posted May 25, 2008 Posted May 25, 2008 I don't think I will go into why I have to have that kind of protection, but I do. I agree some what with your assessment of some Spyware programs, but the good ones are also ant-malware. I do get nailed once in a while. It's been a while since I've had to deal with a nasty one but as they say-it's not if, it's when! :bomb: Quote
