v3jqv6mhl9bn Posted February 26, 2009 Posted February 26, 2009 (edited) I made a switchless .NET 1.0 addon, but I've noticed a problem with it. If I run it at SVCPACK along with .NET 2/3/3.5, then the latter does not install.Here is what I use to installdotnet10.exe /q:a /c:"install /q"dotnet10sp3.exe /qThis is called from a batch file from a Winrar sfx Edited February 26, 2009 by CODYQX4 Quote
ricktendo Posted February 26, 2009 Posted February 26, 2009 Yes you are correct, you discovered the problem why .net 1.0 is never included in .net framework All In Ones's...For my spanish .net 1.0 I install it during RunOnceEx Quote
v3jqv6mhl9bn Posted February 26, 2009 Author Posted February 26, 2009 I always wondered why that happened, anyway the OnePiece addon that is supposed to be used with my TabletPC addon can be used with AIO's. If only I can make that removable... Quote
