I can't enter wincert.net since 25.02.2009 and some of my friends too.
I can enter now using hotspot shield or using vtunnel.
Why ?
Sorry for my poor english :wub_anim:
Is this problem only from Turkey? Is there a problem any other nation ?
Why ?
There was an DDoS attack on our servers and a lot of IP addresses were blocked. I'll see what I can do.
If I'll need you IP addresses, you'll probably be able just to write first three octets, like 223.345.234.x
I'll keep you informed..
I just got this info from my host:
I have checked your domain from different parts of the world and it is loading fine for me. You can confirm it from any proxy site like atunnel.com.
If you can't access wincert, please send me a PM containing your IP Address which you can find out here http://www.whatismyip.com
You should also run tracert wincert.net command in command prompt and send me your results.
Thx
İt's work normally now.
Thanks.
Please inform me about IP addresses from other members who have trouble accessing wincert.net
Thx
Some of them have dinamic ip. What can we do ?
Thanks
Please check if they are only changing the last octet of their IP address. For instance, if they change only x (156.123.156.X)
I will then update our ticket there..
Not only the last octet.
For example ip adress start with 78.180.243.x
After modem Close/open , the ip is start with 88.234.76.x
İt's difficult to solve problem I think.
They can accessing, using vtunnel..etc.
its not important.
Only two member said that have a problem.
Posted (edited)
I'm facing the same problem with random intervals. It's not that my ip addresses has been blocked since both my home and work ip addresses are static. Now i can reach, the other time i can not... I'm getting a timeout error those times.
(The last i had it was Saturday i assume.)
Edited by Nomadturk
Our host said that 88.234.76.x and 78.180.243.x IP addresses are on the white list.
All of you who experience problems accessing Wincert, please go to http://www.whatismyip.com and wrote down your IP and run "tracert wincert.net" command in command prompt.
thx
Tracing route to wincert.net [69.73.170.7]
using 72.9.239.170
Can you please make a screenshot of traceroute results.
Thx
N1K, can you check for these ranges as well?
213.238.140.*
213.238.141.*
Will do.
213.238.140.*
213.238.141.*
This IP ranges have been unblocked. Please check it out.
N1K all I have is Request timed outs
1 * * * Request timed out.
2 * * * Request timed out.
Your issue should be fixed now too. Please check it out.
Working now... What did you do? Block a whole country? The world? (:
Not me, our host had a severe DDoS attack, and this was necessary thing to do. :)
