hi succeeded with me
but extract to DP_Chipset_wnt5_x86-32_902.7z
and use nlite integrate driver in driver and choose all driver but problem in size
1mg to 3mg & 5mg to 11mg
Please write Do you succeeded or failed
Thank you
im wait
Posted (edited)
Cool but DriversPack work perfectly in txt-mode, why use this Addon ?
Edited by Pho3nX
  • 4 weeks later...
What is new ?
[general]
builddate=2009/03/07
description=Vortex SATA/RAID driver integrat
title=Vortex SATA/RAID driver integrat
version=3G.1.1
website=http://www.vortex-eg.com
This is from entrie_sata.ini inside the archive. Looks the same with the old one.
Added to complete addon list.
why add it to the list when i don't think its been proven it actually ever worked properly
if anything it should be deleted so people dont f*** up their builds with this thing
thx.. i just add the amd and intel text drivers manually. thats the safest bet. thx again
just use http://driverpacks.net/
it have the tool to do this job just perfect
Posted (edited)
oh yes ofcourse.. thx for reminding me that bro. :welcome:
between can you tell me where shall i look for windows7 addons!! for both x86 n x64
Regards
Edited by rollcage
  • 2 years later...
Posted (edited)
Aafter all integration has been done Please integrate with RVM Integrator. I am Succeeded.But In some DVD Writers {LG} Are not able to read the file Winnt.sif
Edited by sunilboudh
This addon is STILL broken...
The entries file is built complelty wrong...
I don't suggest this one.
After further review I am closing this thread as the OP never posted a file size and hash as was asked A LONG TIME ago!!!
