Posted January 7, 200718 yr Y'z ToolbarAuthor :: M.YamaguchiY'z ToolBar allows the user to change the toolbar icons in Explorer and Internet Explorer.The user can also create and add their own themes.Features:Change the toolbar icons in Explorer and IE.It can use 17x17 pixels to 64x64 pixels as the icon image sizes for the toobar themes.Use either bmp and png for the icon image files to create the toolbars. Using the png file format allows for alpha blending, the user has the ability to create smooth icon toolbar images with drop shadows and without jaggy edges.It does not rewrite any Windows system files.Access Y'z ToolBar by right-clicking the toolbar in Explorer or IE and choosing it from the toolbar customizing pop-up menu.Makes it possible to hide the Windows flag (throbber)in Explorer or in IE's toolbar.Available in different languages (Japanese and English).Download: Y'z Toolbar 1.3---------------------------------------------------------Y'z ShadowAuthor :: M.YamaguchiY'z Shadow adds a shadow effect to the windows in pursuit of the "beauty of a shadow".It also allows the user the option of making menus transparent.Features:Attaches a drop shadow to the windows.Makes it possible to select one type of shadow effect in the active window and a different one in the inactive window.The user can choose to have transparent menus. There is also the option of selecting the degree of transparency in the menus.Add a drop shadow to the menus.Add a drop shadow to the taskbar.The width, depth, etc. of the drop shadows can all be set to your liking in the settings dialog.It works correctly with either WindowsXP styles or classic style.The user can specify application windows that you wish to exclude from having the drop shadow effect.The user can choose a setting that will automatically adjust your windows so they do not overlap or interfere with the taskbar.Available in different languages (Japanese and English).Download: Y'z Shadow 1.9
