[RunOnceEx] Macrium Reflect Free Edition 4.2 build 2525 (This package is for 32 bit system only)
Homepage
The fastest disk imaging software.The only free XP and Vista compatible disk imaging software with BartPE and Linux based recovery options.
- Create a disk image whilst running Windows using Microsoft Volume Shadow copy Service (VSS)
- Image to Network, USB, FireWire drives and DVD
- Built in scheduler.
- 32 bit and native 64 bit versions.
- Industry leading compression levels and speed.
- Linux based Rescue CD with Network access and full GUI. Only 6.5MB in size!
- Built in CD/DVD packet writing engine. Supports packet writing to DVD DL media with Windows Vista.
- HTML log files
ROE_MacriumReflect422525FREE_addon.cab
Size: 14.45 Mb (15,515,200 bytes)
MD5: 1F245756879E69AC0D17E06939D8BFDB
1) Create a backup image by right-click on the drive, such as C:
2) Restore image using supplied recovery iso or using BartPE plugin. Shown here using BartPE method
Edited by Geej
  • 8 months later...
Updated to 4.2 build 2409
Downloaded installer is v4.2.2376 but when connected online, the program will prompt for download patch to v4.2.2409
http://img694.imageshack.us/i/updatepatchprompt.png/
Hence this time, the package includes program + patch file to v4.2.2409.
Main program is installed silently,
Patch program is install-wizard style. (You will see the installation screen but do not need to click to install)
