Solid Capture is a screen capture toolkit that allows you to take snapshots of anything on your computer screen. These snapshots can then be saved as image files, used with an image editor, exported as text, converted to a PDF document, e-mailed to a friend or co-worker, pasted into a presentation, and more.
Specifically, Solid Capture allows you to capture the following:
Screen - Captures everything on your monitor (full screen). If you use dual monitors, you can capture both screens.
Window - Captures an entire window, multiple windows, or a component of a window such as a panel or toolbar. The window capture function also allows you to capture drop-down menus and sliding menus.
Rectangle - Draws a rectangle of any size around an area on your screen to capture anything within.
Color - Selects and copies any color on your screen to a palette.
Text - Extracts the text from a screen capture.
After you’ve captured what you want, you can choose what you want to do with it. The following are some of the options that Solid Capture offers:
Save to clipboard - Your screen capture can be saved to your clipboard. You can then paste it directly into a document, e-mail, or any program that allows you to paste.
Save to file - You can save your capture as an image file for future use.
Edit - Allows you to import your capture into your default editor for immediate editing.
Print - Allows you to format and send one or more captures to the printer.
E-mail - Lets you easily send captures via e-mail. You can embed your captures in a message, send captures as attachments, or create a PDF and send it as an e-mail attachment.
Create PDF - Allows you to create a PDF using one or more captures.
Copy Text - Copies text in a screen capture to your clipboard to be pasted into a document.
Edit Text - Exports text contained within an image to the text editor of your choice.
In short, Solid Capture not only gives you the ability to capture just about anything on your screen, but also allows you to easily work with your captures.
1.goto this pagehttp://www.soliddocuments.com/registercode.php?product=SolidCapture&appcode=SOFTFREE&locale=9
2. Enter your REAL email address, name and click Register.
3. Check your email and note down the User Name, User Email, Organization and Unlock Code.
4. Download the latest version of Solid Capture v3 and install.
5. Run Solid Capture and select “I already have an unlock code and would like to unlock Solid Capture.”. Enter the exact information and you now have a fully licensed Solid Capture screen capturing software.
Ifound it on raymond.ccblog So THANKS TO RAYMOND
Edited by mona
