There should be a box at the top with the default name ie Win7Addon.7z
Just before you click ok just type in .WA instead, if that still does not work then you might have to show all extensions and rename it manually, or just use the Addon Maker tool within W7T.
TNX Legolash2o,
it works :thumbsup_anim:
BTW, is there any plugin (dll) enabling Windows_7_Toolkit_0.7.0.50 to run on WinXP. Because by launching it on WinXP I get "Invalid OS; This program can only be used on Windows 7" message
Regards
  • Replies 54
  • Views 62.2k
  • I am having trouble installing Installwatch. Whenever I run the setup file I get am error saying "Unable to execute. "C:\Users\Sean\AppData\Local\Temp\pft1~tmp\SETUP.EXE" /SMS" Then I click on the ok
  • Yea, manually install my addon using the inf file: 1- Extract the addon to a sub dir 2- Create a folder called i386 (Optional) 3- Move the .cab file into the i386 folder (Optional) 4- Right click the
  • For those who want files in the user profile folders... Use something like: [CopyFolder] Folder1::Users\Default Folder1::Users\Default\AppData:: [CopyFile] Folder2\1.exe::Users\Default Folder2\1.exe::
TNX Legolash2o,
Regards
Window 7 Toolkit only works on windows 7...
The latest alpha lets you run it on XP and Vista BUT and this is a BIG BUT..... You have to have DISM & Imagex in the correct place for it to work. (Pretty much the same place as Win7.
Wimgapi.dll in System32 folder
Dism.exe in System32 folder
DISM folder in System32 folder
etc...
Edited by Legolash2o
  • 4 weeks later...
Crap Cleaner for both x64 and x86
Name=Crap Cleaner
Creator=Legolash2o
Version=2.18.878
Arc=x86!
Description=Cleans all the crap on the computer
[CopyFolder]
CCleaner::Program Files
[CopyFile]
CCleaner.lnk::ProgramData\Microsoft\Windows\Start Menu\Programs
the description says for both, but the example shows for x86 only... just thought I'd point that out. It should be Arc=x86, correct?
  • 8 months later...
It's been quiet on this thread for a while - not sure if it's the correct place to post this, but if an addon specifies arc=x86 and in the registry files refers to program files - is W7T smart enough to change this to program files (x86) - I know it does this for the tasks file, but wondering about the registry files???
Thanks
Mick
Edited by Madz
I can't remember LOL. Just create an x86 addon and a seperate x64 addon. I really can't remember lol, it's been a while since i've updated the code.
I didn,t undestand actually i have modified my imageres.dll, explorer.exe and Shell32.dll both 4 32 bit and 64 bit for 32 bit i understant we have to select system32 option but for syswow64 how we can replace and wont it will say unable to replace the system files or any error while replacing and does i have to add command to copy the files with admin rights. Kindly guide me properly
So will there be new release for this and when we can expect this
when you add the file, just type in "Copy To" Windows\SysWOW64\
I'll add SysWOW64 to the list :)
thanks 4 such a nice tool but why dont you change the Gui like Rt 7lite (a scrap) or vlite, Gui is much easier, can we get the offline guide in pdf format
Kindly guide me on this also can we select the default theme in W7 Toolkit.
  • 4 weeks later...
Since it seems not only is InstallWatch not in development, but their website is down, I'd prefer to find new developments (& more Win7+ compatible) file/registry change finders. Here is what I found:
WhatChanged by Vista Software / vTaskStudio
free, portable, track only 1 drive?, not updated in a year
http://netbooknetwork.net/2011/track-file-registry-whatchanged/
http://www.vtaskstudio.com/support.php
TrackInstall by Matthias Withopf
free, track multiple folders & drives, updated once in the past 2 years
http://www.addictivetips.com/windows-tips/track-change-in-registry-file-system-with-trackwinstall/
http://translate.google.com/translate?u=http%3A%2F%2Fwww.withopf.com%2Ftools%2Ftrackwinstall%2F&langpair=de%7Cen
Integra System Monitor
beta, nice GUI, track different drives at once, might be slower, updated yesterday :)
http://www.addictivetips.com/windows-tips/monitor-and-compare-windows-system-state-files-registry-changes/
http://www.moosoft.com/integrabeta
I'll test one or more of these to see if they work. If anyone has experience in these, please let me know!
Only one I use is regshot...
Once you get it configured to ignore all the stuff you dont need... Works great....
Just my opinion :)
Thanks! But what about where all those files go?
Depends on how complicated the addon is going to be...
I have used many different programs at the same time..... Installwatch to monitor files, regshot for the registry, etc.....
(There is another I use to monitor files, but cant think of it at them moment. Not at home to look..)
If it a complicated addon, it can get very interesting....
Most dont get into to many problems....
Now a addon like Office 2010... Thats a whole different story.... Took me almost week to get that sorted.... It was
a royal pain!
Edited by *Reaper*
  • 5 months later...
greetings all. i am having trouble with the installwatcher link. it seems to be gone. could someone post a new one, or a torrent plz?
TIA
diddi
  • 3 months later...
@diddi
You can find it here
P.S.: no one is using torrents any more :)
@caphp, you are wrong on both counts. Your not-so-helpful link just points essentially to Google, as I know you know, so it pointed nowhere. At least you could have filled in the search field for him. I don't consider myself a total idiot, but it took me a few moments to find a valid link for InstallWatchPro.v2.5c, freeware, which was what Legolash2o reccommended using. Having the correct app name helps. :) Here is one possible link http://www.brothersoft.com/installwatch-download-9407.html. Also torrents are very much alive and well, especially since several of the free hosting services no longer allow file sharing. In fact things like DriverPacks are officially distributed ONLY by torrent.
  • 1 year later...
