UtCollector Posted April 11, 2009 Posted April 11, 2009 Here is ImgBurn V2.4.4.0English only. You can download other language files ad there homepage.Features:ImgBurn is a lightweight CD / DVD / HD DVD / Blu-ray burning application that everyone should have in their toolkit!Read - Read a disc to an image file Build - Create an image file from files on your computer or network - or you can write the files directly to a disc Write - Write an image file to a disc Verify - Check a disc is 100% readable. Optionally, you can also have ImgBurn compare it against a given image file to ensure the actual data is correct Discovery - Put your drive / media to the test! Used in combination with DVDInfoPro, you can check the quality of the burns your drive is producing ImgBurn V2.4.4.0:Homepage:Install from: Sillent addonMD5 hash: C21FAEE129B7F5365BCAB2F6701F5A96File Size: 1.98 MB (2,079,972 bytes)Download here:Change log: Quote
