January 17, 200718 yr Royale Remix Full v1.4.6MD5: ED224B222191F7131D1F403EDB97AFA9Size: 2.64 MBWebsite: http://www.deviantart.com/deviation/44294818/
January 27, 200718 yr great theme (I love royal noir) but login and logout screens are missing (I mean default luna theme are used)I know that they are not included in the pack from the author but I found on web them separately (login is a loginui.exe replacement, logout is a dll)...If you want I can search for the links so you can create a real full royale remixed theme psis it right that logut text is in english on non-english xp version?
January 27, 200718 yr Author Im stumped on that question dude... I have not a clue if its multilanguageAs for the log out not being correct thats the authors fault, I think the log out stuff is located in shell32.dll
January 27, 200718 yr you are right anyway, I found them... these are the link so maybe you can include them in your addon to make it more complete here is logout screen (shell32.dll replacement)http://forums.hardwarezone.com/showpost.ph...mp;postcount=55here is login screen (logonui.exe replacement)http://www.themexp.org/preview.php?mid=169...oir+English.ziphope you'll appreciate I made a little search and found that logonui/shell32 etc are not multilanguage because text is inside the file... maybe I will translate them to italian so you can release an italian version of the pack in the future
