Posted March 13, 200916 yr Hey bud....Found a small error....In the tasks.txt file.....The description for crap cleaner is actually a description for 7-zip also... the shortcut wont get copied correctly.....[CopyFile]CCleaner.lnk::C:\Users\Liam\AppData\Roaming\Microsoft\Windows\Start Menu\Programsshould be:[CopyFile]CCleaner.lnk::C:\ProgramData\Microsoft\Windows\Start Menu\ProgramsStill appears that the registry settings are not taking......Damn protection :censored:
March 13, 200916 yr Microsoft had changed the registry key permissions responsible for recycle bin context-menu. I think this is fixed with build 7048 and later. The main reason i believe this is because i can now install CCleaner normally and have the context menu's there, on previous builds before 7048 when i installed CCleaner... the context menu items on the right bin were not added.EDIT: Fixed CCleaner description and shortcut path, thanks
March 16, 200916 yr Author Hi Reaper what of Extension: WA Reapers_WinRar_3.80_Windows7_AddOn.WAwhat of WaThat is the extension that Windows 7 Toolkit uses....You cant use these with vlite or anything else.....Windows 7 Toolkit ONLY!
April 2, 200916 yr Nice one, you did not have to include the "Bitlord Files" folder though with the 3 shortcuts, i will test it and if it works i will add it to the Addon List in W7T Weldone
April 2, 200916 yr Menu items and everything seemed to have loaded fine, couldn't do a full test tho EDIT: Although your .reg file works, you could have removed any temp values i.e.MuiCache, etc.. but i've cleaned it for you
April 19, 200916 yr Can u made addon like Kels VistaCpl Addon for Windows 7? All utilities in this pack are very good.Used wrong sense words. Sorry, my english is too poor. Edited April 27, 200915 yr by Jatin Beniwal
April 19, 200916 yr Please don't just "Clone" my whole cpl pack as Jatinbeniwal suggested.I would feel like it was stolen.
April 19, 200916 yr Author I wouldn't do that....I'm just putting in what I personally use....The next few apps that are going in, are not in your pack at all...
April 21, 200916 yr Please don't just "Clone" my whole cpl pack as Jatinbeniwal suggested.I would feel like it was stolen.I agree, please do not copy/convert/clone, etc.. anyone else's work, if you wish to do so then please ask them if you can first bearing in mind that if they say no, you cannot copy it.If someone has released an addon which has been copied and the original creator contacts me to remove it, i will.Thanks@Back on topicNice addon, sorry i have not been replying much been very ill lol. Nice work as usual Reaper.
April 27, 200915 yr Please don't just "Clone" my whole cpl pack as Jatinbeniwal suggested.I would feel like it was stolen.I first requested kels :confused02: that u made an addon for W7T too. U take it in other way. Everyone knows that Kels VistaCPl work with windows 7 too. Here i don,t mean to clone it but make an addon like that. Edited April 27, 200915 yr by Jatin Beniwal
April 30, 200915 yr @Jatin Beniwal:After that kind PM I recieved from you over at msfn (Ya know the one where you freaked out over my wimfltr installler) I tend to just ignore you...
April 30, 200915 yr @Jatin Beniwal:After that kind PM I recieved from you over at msfn (Ya know the one where you freaked out over my wimfltr installler) I tend to just ignore you...I send u a PM that means its for u only. I know what freaked u r telling abt. Same thing u have done in tweaks section of w7t. If u remember on my wording " If anyone having problem let me know also u can post ur own tweaks and demand tweaks that u like to add." You also freaked like stop yelling like some words. I am not going to complain but u know ur response at msfn. "How dare u talk me or something like that" Give respect to others and u get it too. By the way this is just misunderstanding between us. I thing u forget that start in a new way.
April 30, 200915 yr Ok, let's end the arguing please. Please stay on topic.EDIT: Removed irrelevant posts.
May 1, 200915 yr Do not clone any one work. It is already posted by Legolash2O & the link is below. Also included in W7T beta also. Post only new addons that work with windows 7 too not posted in forum before.File hippo update checker
May 1, 200915 yr His version is newer and i don't mind, if someone wants to make newer versions of MY (Legolash2o) addons then go ahead, but that does not mean you can "clone" other users addons Saves me time because i don't have to update mine and it also helps users how to make addons
