Posted May 1, 200915 yr Error while discarding and Also show incorrect description regarding to image. Edited May 1, 200915 yr by Jatin Beniwal
May 1, 200915 yr Author And one request also. Is there a way to give mounting path while using Addon Integrator. As it always shows not enough space because of low disk space in windows drive.
May 1, 200915 yr A)I get the discarding error too, hopefully there will be a new WAIK RC for Win 7 so i use updated WimFltrs and wimgapi.B)Description problem has already been fixed in my latest buildC)This is easily possible, i will see what i can do
May 1, 200915 yr Author I also tried to use waik with RC got an error. Then i thinks its a problem with my system. Now it confirmed.
May 1, 200915 yr I meant the RC version of WAIK, but I think it's WIndows 7. It works great on some builds but yet works crap on others. It's strange.
May 2, 200915 yr Author I meant the RC version of WAIK, but I think it's WIndows 7. It works great on some builds but yet works crap on others. It's strange.I m also going to say same thing that with WAIK for windows 7 Beta I m unable to open image of RC build 7100. Everytime i got sn error while rebuilding catalog file.
