Posted May 1, 200915 yr Create, edit, extract, convert, compress, encrypt, mount CD image file!!!PowerISO is a powerful image processing and file compression tool, which allows you to create, extract, compress, edit and convert ISO/BIN image files, and mount these files with internal virtual drive. And most of all, the compressed files can be used directly without decompressing. Edited November 9, 200915 yr by jamesbebby
November 10, 200915 yr Config.txt Clean & Registry USER;);!@Install@!UTF-8!InstallPath="%SystemDrive%\\PowerISO_4.6_temp"SetEnvironment="hkcu_rdr=HKCU\\SOFTWARE\\PowerISO" RunProgram="hidcon:cmd /c reg add \"%hkcu_rdr%\" /v USER /t REG_Binary /d xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx /f" RunProgram="%SystemDrive%\\PowerISO_4.6_temp\\PowerISO_4.6.exe /S /NCRC"Delete="%SystemDrive%\\PowerISO_4.6_temp"GUIMode="2";!@InstallEnd@! Edited November 13, 200915 yr by remek002
December 29, 200915 yr something is not working in 4.6i add the exe file above to the addon files from above alsowith 7zip of-coursethen when i try to add the addon to nlite it gives me an error sayingUnsupported Fileany help?
