Cyberlink PowerDVD v8.0.2705d INTL
All I can say about this soft is already known. So...
NOTE : You won't take advantage of trial period (30 days) : CL PowerDVD patch ONLY can be apply to ALREADY REGISTERED Standard/Deluxe versions. Then, at the 1rst start, you'll have this screen (in one of the (your) native language supported by this addon):
PREREQUISITES :
  • DirectX 9 (nLite v1.4.9.1+ users: I added section [NeededComponents] to Entries_PowerDVD.ini to prevent it from removal)
  • Remote Procedure Call (RPC) Service present
FREE INCLUDED PACKS :
  • MPEG4 AVC Pack
  • Mobility Pack
LIMITATIONS :
  • TRIAL VERSION
  • This addon is ONLY for PowerDVD 8 Standard/Deluxe versions
  • Blu-ray disks Playback not supported
  • Not work in virtual machine (DirectX problem)
ITEMS REMOVED/DELETED/NOT-INSTALLED :
  • Google ToolBar
  • Moovie Live beta
  • Files Language.exe, Language.ini, Shortcut.ini (Directive ProfilItems do the same job)
FILE ASSOCIATION : .RMX
BUG : (Non-English users ONLY)
Local Shell command Play with PowerDVD 8 (i.e French-->Lire avec PowerDVD 8)
is translate to Play with PowerDVD 8 (keep english strings)
after 1rst start of PowerDVD 8. I Dunno why; otherwise, it's not my fault.
OTHERS INFOS :
  • Replace, if needed, info below with yours (located in PowerDVD.inf Strings section) :
    UserName	 ="Ken@fri"
    Company_Name ="GSK CORP."
TRANSLATION : All my apologize for all the incorrect translations I made (I use online translators) :sweatingbullets: . I tried to do my best. Feel free to edit PowerDVD.inf and fix errors. (U can send me the correct sentences too, pleaz :giveheart: )
//////////////////// IMPORTANT //////////////////
Addon ONLY tested on real environment (Right-click on PowerDVD.inf -->command Install).
Editor : CyberLink
License : TRIAL
Version : 8.0.2705d
Editions: Standard, Deluxe
OS : XP/Vista
Language: MULTILANGUAGE (English, French, German, Italian, Spanish)
A FRENCH VERSION ADDON is available >>HERE<<
///////////////////////// PowerDVD 8.0.2705 AIO True Addon (DEU, ENU, ESP, FRA, ITA)///////////////////
Taille : 32.3 Mo
MD5 : FA50884CFBA33927CB54C3E256B80C8D
