Posted (edited)
When I open w7t, it downloads a new database normally and it wants me to download and install wim filter
When I click "download and install" button, it downloads something but the program freezes and i can't do anything
What can i do?
my os is windows 7 bulid 7100
my waik is windows 7 beta waik (i tried vista waik)
w2t version is 0.1.3 (i tried 0.1.2)
sorry for my bad english...
Edited by XC*LUSiVE
Posted (edited)
Thanks lego for addin this "skip" option. Now it works, and no more offline mode as well. Although it has the same problem as before "cant connect to remote server" (for the wimfltr. inf file) but with the skip option, it works. (did not try mounting any images yet, will let you know)
Thank you
EDIT:
It mounts wim images, but i get this error when unmounting the image
EDIT: 2
I forgot to mention, it unmounts perfectly with "discard" but if i select "save and unmount" option i get the error above
Edited by shahed
