December 7, 201014 yr Author Hello JonnyBoy,This is version 6, right? latest is 7, a lot of improvements, a very wanted one specially on Windows Server 2003.http://www.microsoft...&displaylang=enI am not sure. The files used to create these installers are from Windows 7, version 6.1.7600.16385 32-bit. Unless there has been an update to the Windows 7 version, then this is the current version.***UPDATE***My Windows 7 VM, which is current has the same file version. Edited December 7, 201014 yr by Jonnyboy
December 7, 201014 yr My mistake, you're right. Version number can lead to this confusion.Thank you, I'll try ASAP.Edit: if you extract the XP Remote Desktop update from http://www.microsoft.com/downloads/en/details.aspx?FamilyId=72158b4e-b527-45e4-af24-d02938a95683&displaylang=en , it includes more files to be updated (dependencies maybe, on my tests they were necessary to be updated too)aaclient.dllaaclient.dll.muimsrdpwebaccess.dllmstsc.exemstsc.exe.muimstscax.dllmstscax.dll.muitsgqec.dlltsgqec.dll.muitswbprxy.exewksprt.exewksprt.exe.muiwksprtps.dllI am not sure. The files used to create these installers are from Windows 7, version 6.1.7600.16385 32-bit. Unless there has been an update to the Windows 7 version, then this is the current version.***UPDATE***My Windows 7 VM, which is current has the same file version. Edited December 7, 201014 yr by zzzzzz
December 7, 201014 yr Author My mistake, you're right. Version number can lead to this confusion.Thank you, I'll try ASAP.Edit: if you extract the XP Remote Desktop update from http://www.microsoft...&displaylang=en , it includes more files to be updated (dependencies maybe, on my tests they were necessary to be updated too)aaclient.dllaaclient.dll.muimsrdpwebaccess.dllmstsc.exemstsc.exe.muimstscax.dllmstscax.dll.muitsgqec.dlltsgqec.dll.muitswbprxy.exewksprt.exewksprt.exe.muiwksprtps.dllThat file updates more than just RDP. I will look into it in a couple of weeks and update if necessary. Those files were not required for it to work on my install of WinXP SP3.Just out of curiosity, why don't you just apply this update to your source?
December 7, 201014 yr applied, working, but the missing files were not updated (kidding, sorry) That file updates more than just RDP. I will look into it in a couple of weeks and update if necessary. Those files were not required for it to work on my install of WinXP SP3.Just out of curiosity, why don't you just apply this update to your source?
December 7, 201014 yr Author applied, working, but the missing files were not updated (kidding, sorry) I was referring to the link that you provided. Just apply that to your 2003 Server source, instead of using my addon.
December 7, 201014 yr I've tried that before with no success, this EXE requires a XP source, but extracted files works fine... that's why I'm asking here a true addon... :crying_anim02: I was referring to the link that you provided. Just apply that to your 2003 Server source, instead of using my addon.
