Open Selected URL 1.0.1.0
Geej
Open Selected URL 1.0.1.0 (an Internet Explorer Context Menu Extension)
Homepage: http://www.muvenum.com/
Screenshot/Guide
For Internet Explorer 6, 7, and 8
Sometimes you'll find urls on websites that aren't clickable. (like the homepage above :) )
Use Open Selected URL to select the url, right-click to open the context-menu, and click to open the non-functioning link in the current tab,a new tab, or even a new window.
OpenSelectedURL_True_Addon.cab*
Size: 8.5 Kb (8,709 bytes)
MD5: 8BC57B1DC2E661B42D4F8DC37A7A793B
*My first true addon. Tested ok on XP VM with IE8.
The context menu will also appears on IE-based web browsers such as Maxthon & Slim Browser.
=== Edit ====
Add:
[SYSOC.EDIT]
%17%\sysoc.inf,Components,OpenSURL=*
to the inf for uninstall.
If can't open url in new tab, you need to apply IE7/IE8 tweak as:
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\TabbedBrowsing]
"PopupsUseNewWindow"=dword:00000002
Edited by Geej
Link to comment
Share on other sites
  • 6 months later...
