Posted August 7, 200618 yr in this one i teach you how to make the "depth reflection" effectfirst make a 400*200 canvas and fill it with your favorite colorthen pick your favorite font with a color you think will look good on the background you chose and on a new layer type your favorite word(s)next, duplicate the text layer. Then go Image>Rotate>Flip Layer Vertical and move it directly under the original text layer, so its almost touchingnow, go to the rectangular marquee tool and set feather to about 4px (on the top bar)Simplify the duplicated layer and then, on the duplicated layer, select about half of the text, right click and click "select inverse" hit delete, deselect and dull the opacity of that layer to 50%and that's it!when you get good like me, you can make things like this in case your wondering, this is the specks for the last image edges=feathered 4px, twiceEffect=5px Simple pillow and 1px soft shadowBackground gloss= white fill 20% opacityBackground color=Blue shades gradientand don't be afraid to bend the rules of photoshop to work to your advantage Coming Up: Gloss-e-ness
October 5, 200618 yr hey wolf, i tried your tut and with a little trail and error, i made it work!i am going to show you next time because its on my own pc and im on my work now.but i just wanted to say, keep it up :thumbsup: damian
October 6, 200618 yr Author hmm, please show me the error, i may have missed a step, i use this effect so often it becomes hard to explain it
October 9, 200618 yr hmm, please show me the error, i may have missed a step, i use this effect so often it becomes hard to explain it hi wolf, well the "error" was really a misguided me .i could not find the buttons you said because i have the dutch version of photopshop man.so its no big thing!here is my result! :thumbsup: damian666damian.bmp
October 9, 200618 yr Wolf why dont you download a PC Screen Recorder thingy and do some video tutos for us like this Vista Glass tuto I sent you
October 9, 200618 yr Wolf why dont you download a PC Screen Recorder thingy and do some video tutos for us like this Vista Glass tuto I sent youExcelent idea, woooolf, do it please!! :clap:
October 9, 200618 yr Author @damian666Thanks @Kelsenellenelvianhttp://www.wincert.net/forum/index.php?showtopic=63 @ricktendo64 & N1KGood Idea! I'll Make A couple like that
October 12, 200618 yr hi wolf, i was wondering if you could tell me how to make that reflection less cutt of.i'm trying to make a bitmap for the hhdwiz.cpl of xp but when i trie this tut, it looks kind of cut of.do you know what i mean?is there a way to let it flow out or something like that?damian666 vistabmp19.bmp
October 13, 200618 yr Author the trick is feathering, NOT distortion.Use the rectangular marquee tool and set the feather to about 10select the part of the icon you would like to make "flow out" (be dimmed) and hit delete.If you think its necessary dull the opacity of the layer to whatever you feel is best, i say about (50-40%%)now in case you'd rather not go to all that trouble i made some of my own and since were using vista icons, a vista interface would look superb!happy photoshoping :welcome:
October 16, 200618 yr wow thanx wolf, your the photoshop god man!i will use your pics in my ua cd if you do not mind.but i will try to make them myself, so thanx for the explanation.bye bye damian666
