Ceedo Enterprise is a complete application virtualization solution designed to meet the needs of the enterprise. Ceedo’s unique approach to application virtualization enables multiple applications to be virtualized together to create a virtual work environment.
Ceedo's environment allows the separation of applications, application settings and data from the operating system, yet allows the applications to interact with one another. This ability reduces the complexity of managing the lifecycle of desktop workspaces by an order of magnitude.
The separation allows easy deployments of applications, quick restoration of user environments during disasters, improved business continuity during PC failures, better control over application licensing, and more.
The client can run fully integrated into the Windows UI allowing seamless integration and usability, or using a special UI enabling the users to access a separate isolated environment from their Windows PC.
WEBSITE http://www.ceedo.com/products/ceedo-enterprise.html
I just found this the other day and found it very useful. No need to look for or create portable apps when you can install any app to your USB. With a start menu and dock, it is easy to organize and launch applications with ease.
Edited by LUZR4LIFE
