Posted January 26, 200718 yr Here you go:Which number should be filled on the red spot?here you find info on how to solve the sudoku.Good luck. Edited January 26, 200718 yr by Martin L
August 28, 200717 yr Here you go:Which number should be filled on the red spot?here you find info on how to solve the sudoku.Good luck.The answer is 5 :welcome:
