Posted May 27, 200916 yr Here is something for those who want to work with WIMGAPI and VB .NET. Just add the module below to your project and use the examples below that to do your tasks. I will be updating it with more functions. If you know any which have not been added yet please post a working example WIMGAPI Module v1.0The places where you see the number 1, that is the image index.Mount ImageIf CWIM_MountImage(1,"C:\Wimfile.wim","C:\MountPath") = true then'DO THISelse'MSGBOX("There was an error mounting this image")end ifUnMount ImageIf CWIM_UnMountImage(1,"C:\Wimfile.wim","C:\MountPath",True) = true then'DO THISelse'MSGBOX("There was an error unmounting this image")end ifDelete ImageCWIM_DeleteImage("C:\WimFile.wim",1)GetWIMInfoDim WImInfo = CWIM_GetWimInfo("C:\Wimfile.wim")Capture ImageCWIM_CaptureImage("C:\FolderToCapture","C:\NewWim.wim",WIM_COMPRESS_LZX,"C:\Temp")Export ImageCWIM_ExportImage("C:\OriginalWim.wim","C:\ExportedWim.wim",1,"C:\Temp")
August 18, 200916 yr Hi,I use the capture function in my project but i'd like to edit the properties "NAME" and "DESCRIPTION" with 2 textBox on my Form. My question is : Must I use the "SetImageInformation" function to do that ?I have read all of this document and I can't really find my way : My linkhttp://msdn.microsoft.com/en-us/library/dd834960.aspxhttp://msdn.microsoft.com/en-us/library/dd834960.aspx...
August 31, 201213 yr Resurrecting an old thread, I know, but it would be wonderful if the attachment could be replaced / fixed -- not showing it as active or valid. Thanks!
September 10, 201213 yr Author I no longer have the code anymore, i think i got rid of it years ago, it's available via google if you look in the right places. Sorry.
