It has been a year i have been making themes & customization apps.
so here are selected best themes made by me.All themes and apps here are for XP(all sp) only.
Ultimate Green Theme for XP
Ultimate Green is new version of Vista Green theme for XP.
When I first released Vista Green I got good reviews from visitors who
where tired of "Black" Vista theme for XP. They found new taste in Vista Green Theme.
Some of them reviewed that there was too much green in
this theme because of this in this Version I have used Aero Glass frame instead of green frame. This was only green 7 theme when i first released it.
i guess now u can find some more win7 green theme.
( It is also one of my most popular theme it was it sites like Brothersoft.com
stuffheaven.com etc)
Download Link : http://www.deviantart.com/download/1174788...P_by_pri2sh.rar
Note: LS patch is needed to get result as in screen shot. to get file google
you can download from here http://www.windowsxlive.net/download/myvs/tools/lspatch.zip
Vista Night v1 theme
This theme is made by with help of a guy in internet.
I modded this theme and made this as per his reqest.
things i have done shellstyle, wallpaper selection & edit in theme.
Download link:
http://cid-c0c5098f337a8082.skydrive.live....%20for%20XP.rar
WMP12 Replacement for WMP11 XP
WMP12 Replacement will modify existing WMP11 UI to like of WMP12 of Windows 7.
This supports only WMP 11 XP ( all v11 & Language, but only x86/32bit OS ) .
Run "wmp12-replacement-XPwmp11.exe" to install & "uninstaller.exe" to uninstall.
every thing is automatic you don't have to do anything manually.
In this version of wmp12 mod glass look / Aero Look has been decreased and useless
image in .res file has also been removed.
You can also check Windows 7 Replacement Beta2 for Windows 7 Transformation
i have use images from user fediafedia.deviantart.com for this.. before it was dll tha
http://www.deviantart.com/download/1209336...2_by_pri2sh.rar
Windows 7 Properties for XP (v1.2)
Here is new version of windows 7 Properties XP.
It give windows7 Like system properties dialog.
If you have installed Windows 7 Replacement Beta 2 then first run "win7-puninstaler.exe" then run "win7_prop-installerv1.2.exe" .
Download from here: http://www.deviantart.com/download/1186279...2_by_pri2sh.rar
Vista Green Theme
Around Web I saw different themes inspired by vista,
But I found all themes to be common in 1 thing that is its black taskbar
and default vista orb so i try to make different and made this Theme known as
Vista Green where Every thing is green instead of Black. I have made / added green
start button orb(from vista media center) replaced to green scroll bar,checkbutton,
minimize,maximize,close button etc.
Modified Aurora to green look so it can match with theme and released it finally
from my website. This was really great and unique theme and when i released it there was barely any vista green theme.
Download from here: http://www.deviantart.com/download/1091505...P_by_pri2sh.jpg
=================< End >===========================
This are some of my chosen work i hope u like it.
Some unsorted stuffs are available in my dA profile pri2sh.deviantart.com
& my website Vastdown.co.nr.
Thank u
  • 5 months later...
