DanielCollinet Posted May 31, 2009 Posted May 31, 2009 (edited) With the permission of Kel I continue the addon of Notepad++ -> replacing the standard notepad of Windows. Thanks to Kel for his permission. I only updated the stuff did not change something else![updated] 03.19.11[Version] 5.8.7[Link] http://www.megaupload.com/?d=5VWPO4LGMD5: d048a5f8c0a8c20784aa6f4804673decSHA-1: 644b65757e23ff1f118b9afa4ac46c4ae2a48706[Author] http://notepad-plus.sourceforge.net[Credits] KelAfter reading this, I will not update this app anymore.My link Edited April 1, 2011 by DanielCollinet mona 1 Quote
marshall123 Posted June 1, 2009 Posted June 1, 2009 !!! GREAT !!! Thank's my friend. :thumbsup_anim: Quote
niuus Posted July 22, 2009 Posted July 22, 2009 (edited) Gosh man, thank you so much for continuing this. I prefer it over Notepad2 because of the multi-tab.EDIT: Buggers... it won't work with XP64. Any chance to do a compatible one? Edited July 22, 2009 by niuus Quote
ionut_y Posted September 26, 2009 Posted September 26, 2009 (edited) Thanks,one question,can I convert this add-on to RunOnce ? I converted this SpywareBlaster add-on to a silent exe installer using winrar comment section just like this Path=%ProgramFiles%\spywareblasterSavePathsetup=spyblast.infSilent=1Overwrite=1what about this add-on,I've tried but no chance.Thanks. Edited September 26, 2009 by ionut_y Quote
Guest Posted September 26, 2009 Posted September 26, 2009 Thanks,one question,can I convert this add-on to RunOnce ? I converted this SpywareBlaster add-on to a silent exe installer using winrar comment section just like this Path=%ProgramFiles%\spywareblasterSavePathsetup=spyblast.infSilent=1Overwrite=1what about this add-on,I've tried but no chance.Thanks.well it's easy first you don't need the line Path=%ProgramFiles%\spywareblasterreplace it with TempMode to send it to temp and make a folder named "I386" and put the cab file in itthen make the exe and it should work fine Quote
ionut_y Posted September 26, 2009 Posted September 26, 2009 I've removed this line from inf file [SourceDisksNames.x86]1="NotePad++ Files","Note.cab",,"i386"to work for every place I run it.I've extract the content of file note.cab,then unpack with winrar and the comments :TempModeSavePathsetup=note.infSilent=1Overwrite=1It doesn't work,I found no file in \Program Files\Notepad++\ folderThanks. Quote
Guest Posted September 26, 2009 Posted September 26, 2009 I've removed this line from inf file [SourceDisksNames.x86]1="NotePad++ Files","Note.cab",,"i386"to work for every place I run it.I've extract the content of file note.cab,then unpack with winrar and the comments :TempModeSavePathsetup=note.infSilent=1Overwrite=1It doesn't work,I found no file in \Program Files\Notepad++\ folderThanks.no leave that line just remove the I386 from that line Quote
ionut_y Posted September 26, 2009 Posted September 26, 2009 Great !!!!! THANKS A LOT !!!!no leave that line just remove the I386 from that line Quote
Guest Posted December 28, 2009 Posted December 28, 2009 hi DanielCollinetplease upload to hotfilerapidshare dosenallow to download Quote
DanielCollinet Posted December 30, 2009 Author Posted December 30, 2009 Hi Mona,for me it's working(rs). But as you wish your highnesshttp://hotfile.com/dl/22341459/a197570/Kels_NotePad___v5.6.4_addon_replacer.rar.html mona 1 Quote
dacorsa Posted January 2, 2010 Posted January 2, 2010 how install in italian language?i have to change something in inf file?thanks Quote
DanielCollinet Posted January 3, 2010 Author Posted January 3, 2010 (edited) Hi Dacorsa,you can try this(I don't know if it works).Copy the file "italian.xml" and rename it to "nativeLang.xml". Open the "Note.inf" in the addon and add it here1. [sourceDisksFiles] nativeLang.xml = 12. [Note.main] nativeLang.xmlclose and save Note.inf recab note and try and please tell... Edited January 3, 2010 by DanielCollinet Quote
dacorsa Posted January 4, 2010 Posted January 4, 2010 another question:can i add an entry on right key mouse called "Edit with Notepad++"???thanks! Quote
DanielCollinet Posted January 9, 2010 Author Posted January 9, 2010 This is already done in this section [Reg].If you install this addon later on a running system(via inf) replacing won't work. Systemprotection prevents replacing. Quote
Dziubek Posted January 9, 2010 Posted January 9, 2010 Can you also create traditional the addons of Notepad++ (no replace notepad)?thanks Quote
