I am trying to upgrade my RAM. Here is the system Specs for my RAM from HP:
1024MB DDR2 System Memory (2 Dimm)
That's all it says unfortunately.
In PC Wizard 2008 It says:
Type: 2 SDRAM PC2-5300 (333mhz) [DDR-666]
Format: SO-Dimm (67.6x3)
I am looking to upgrade to 2G which means I need to buy 2G since I have 2x512 in my system now.
Can someone lead me in the right direction? What would you recommend.
THANK YOU
Edited by LUZR4LIFE
Either!
I have first-hand knowledge that Crucial has kick-ass support.
I hear Corsair has good support too.
Thanks. I think I may end up going with the Corsair, just because I have known people to get there desktop RAM. But I will wait a few more days before ordering.
I just got my new RAM, sad thing is after installing the 2G stick with a 512 and starting it up, I find out that my laptop only supports 2G, since 512 is missing.
