bigb Posted July 6, 2009 Posted July 6, 2009 Hello everybody.I have been trying to find the resources to modify the above. Does any one on Wincert know where they are located or even if they can be modified.All help and advice is much appreciated.I originally posted this in the Windows Customisation forum without a single answer. Any help would be much appreciated.Original.http://www.wincert.net/forum/index.php?showtopic=6397 Quote
Kelsenellenelvian Posted July 6, 2009 Posted July 6, 2009 That is the typical runonce box...How do you want to modify it?Not much you can do to it. Quote
bigb Posted July 6, 2009 Author Posted July 6, 2009 That is the typical runonce box...How do you want to modify it?Not much you can do to it.Just want to know if it can be done. Maybe change the text or add a background underneath the text.It seems that every other part of XP has been or can be modded. XPTsp is a great tool that I use on my own builds and the runonce box is about the only thing left to modify.Thank you for replying. Quote
Kelsenellenelvian Posted July 6, 2009 Posted July 6, 2009 You can actually enable the XP theme\style border (I will look it uo and post a link to it)Really thats all though.Good news though you can set it to anytheme you have on the disk as long as you patch the uxtheme.dll Quote
Kelsenellenelvian Posted July 6, 2009 Posted July 6, 2009 Do this:http://www.msfn.org/win2k3/themesxtra.htmAnd add the resulting reg file to your cmdlines.txt! Off you go ----> No more crappy win2000 border.OH and for the text find the offending .inf I think from the pic you are using onepieces update pack. Find his main inf and edit the proper strings. Quote
bigb Posted July 6, 2009 Author Posted July 6, 2009 Thank you for your quick response. I have bookmarked the link you gave me and will try it out. Quote
ricktendo Posted July 6, 2009 Posted July 6, 2009 I dont thinki ts Runoce.exe, only thing close I could find to this dialog box was in shdoclc.dll Quote
bigb Posted July 6, 2009 Author Posted July 6, 2009 I dont thinki ts Runoce.exe, only thing close I could find to this dialog box was in shdoclc.dllSorry guys. As ricktendo64 noticed it is not runonce.exe. It is at the final screen before XP starts after setup. Quote
