Posted July 22, 200915 yr Also available via W7T! 51.1MB63C1B8255EAC9C74B52206A669D366E4Description"Windows 7 E" does not come with a web browser, when you integrate this it will popup after install to let you choose what browser you want! Just in case the browser you want is not listed, it also includes a small built-in browser so you can download it yourself Note:You can still use this even if you do not have the E version! Edited September 25, 200915 yr by Legolash2o
July 24, 200915 yr Author Yes, even vista. It was made specially for Windows 7 E as they get no browser. But it will work just as good on NON-EU editions
August 12, 200915 yr well shouldn't you update it with IE8 since thee is an installer now for IE8in this Topicand leave this version for Normal Users
September 21, 200915 yr lego i saw something wired this Quote Arc=Anydoes your W7T accept it if yes i would add it's support to my WA Installer i have been testing the new version when i got with this
September 25, 200915 yr Author On 9/21/2009 at 1:17 AM, DaRk MaDnEsS said: lego i saw something wired this does your W7T accept it if yes i would add it's support to my WA Installer i have been testing the new version when i got with thisYep and also "N/A" (without quotes)
September 25, 200915 yr On 9/25/2009 at 11:06 AM, Legolash2o said: Yep and also "N/A" (without quotes)well ok i added support for both thx lego
September 25, 200915 yr Author 1.0.4 removed Internet Explorer as they will no be "Windows 7 E" anymore
January 15, 201114 yr Author I no longer work on addons, neither do i have the addon anymore I can try and make another one but much better? Edited January 15, 201114 yr by Legolash2o
