Posted July 26, 200915 yr After i ereased all my Music Library, i tried re-add music, but WMP12 won't do it...I try adding the Folders, but it says they are empty(Windows Media Player is 12.0.7600.16385)...Any fix is better..
July 26, 200915 yr Have the folders got music in them and I have a feeling you deleted your music files all together.... WMP12 can delete music files and move them to trash. Look in your trash(Recycle Bin)...
July 27, 200915 yr Author Have the folders got music in them and I have a feeling you deleted your music files all together.... WMP12 can delete music files and move them to trash. Look in your trash(Recycle Bin)...I have all music, as i choose Delete only from Library..And i want get them all back again(To Library) Edited July 27, 200915 yr by Dissscount
July 27, 200915 yr I have all music, as i choose Delete only from Library..And i want get them all back again(To Library)Ok this sometimes happens with me and what i normaly do is highlight all music files (not folders if they are in folders then go into them and highlight all the music files in there) and after you've highlighted right-click and click on Add To Windows Media Player List.It should play them but also it should just add them to the library.This should work.
July 27, 200915 yr Author Ok this sometimes happens with me and what i normaly do is highlight all music files (not folders if they are in folders then go into them and highlight all the music files in there) and after you've highlighted right-click and click on Add To Windows Media Player List.It should play them but also it should just add them to the library.This should work.OMG!!! It's a glitch OR feature like excluding ??!
July 27, 200915 yr Ok i've just did what you've done and i'll get back to you with it.I'll edit this post and tell you how i got on.EDIT: Right i've just got all my music files back into windows media player.What i did is right click on Music (In the list on the left hand side) and click on Manage Music Library. I have my music on a different HDD so what i did was removed that folder. added an album folder. then it added my music files. So then I removed that folder from the Manage Music librarys and then added back the folder with ALL my music files. So if you have yours in the default Music folder add that to the list and it should work.(Please tell me it does!!) LOL
July 27, 200915 yr Author Ok i've just did what you've done and i'll get back to you with it.I'll edit this post and tell you how i got on.EDIT: Right i've just got all my music files back into windows media player.What i did is right click on Music (In the list on the left hand side) and click on Manage Music Library. I have my music on a different HDD so what i did was removed that folder. added an album folder. then it added my music files. So then I removed that folder from the Manage Music librarys and then added back the folder with ALL my music files. So if you have yours in the default Music folder add that to the list and it should work.(Please tell me it does!!) LOLThanks in advance, music is now being added!
