Posted July 30, 200915 yr Mede mogelijk dankzij de volgende personen:HJW, RyanVM, Siginet, Boooggy, MrNxDmx, MEULC, Muiz, Ricktendo64, 5eraph, Tijs, redxiii, mr.Fixit, OnePiece, etc.XP Post-SP3 UpdatePack Nederlands v2.2.8 Updated (22-10-2009 Stefhan)Hash MD5: BBBE0D5E9F219544C6DCB494699B8EF6Filesize: 69,0 MBMirror: MegaUploadContentsKB887606 - The Microsoft XML Parser (MSXML) uses cached credentials incorrectly.KB898461 - Permanent copy of Package Installer.KB909520 - Base Smart Card Cryptographic Service Provider Update.KB917275 - Windows Rights Management Services with Service Pack 2KB922120 - Network Map in Windows Vista does not display computers that are running Windows XP.KB923561 - Update for Windows WordPad Converter.KB940648 - Error message when you open the MyDocuments folder after you resume the computer from hibernation: "You might not have permission to use this network resource". KB942288 - Windows Installer 4.5.KB943729 - Information about new Group Policy preferences in Windows Server 2008.KB944043 - Windows Server 2008 read-only domain controller compatibility pack for Windows Server 2003 clients and for Windows XP clients.KB944505 - DFS clients may access the DFS root server in the remote site even though the DFS root server in the local site is available in a Windows Server 2003-based domain.KB946648 - Vulnerability in Windows Messenger Could Allow Information Disclosure.KB947100 - After a COM application handles an access violation the COM application stops responding.KB947460 - Error message when you try to open a mapped DFS folder after the computer comes out of standby in Windows XP: "<Drive Letter>:\ is not accessible".KB948046 - A Word document is not printed as expected after you install the Windows European Union Expansion Font pack.KB948101 - A USB keyboard does not work after you restart a Windows XP-based computer that has an NVIDIA 680i motherboard installed.KB948720 - You cannot install device drivers in a Windows Server 2008 cluster environment if the drivers contain LZ-compressed files.KB949127 - You cannot establish a wireless connection by using EAP authentication on a Windows XP-based client computer if the Service Set Identifier (SSID) includes a comma.KB949900 - The RunOnce.exe process may stop responding during the driver installation process on a Windows XP-based computer.KB950312 - Error message when you try to start a console-based application, such as Cmd.exe, on a Win XP-based computer: "The application failed to initialize properly ...".KB950616 - An audio application that uses the Portcls.sys file may stop responding when you run the audio application on a computer that is running Windows XP.KB950668 - Windows Explorer crashes when you drag a file onto the desktop during a file transfer that was started by a Flash-based application that uses an ActiveX control.KB950762 - Vulnerabilities in Pragmatic General Multicast (PGM) could allow denial of service.KB950974 - Vulnerability in Event System could allow remote code execution.KB951066 - Security update for Outlook Express and Windows Mail.KB951163 - When you try to use the MSTSC command from TS Client 6.0 to connect to the local Win XP-based computer, a black screen may appear for several minutes.KB951376 - Vulnerability in Bluetooth stack could allow remote code execution.KB951531 - The W32Time service does not synchronize the CMOS clock time to the Internet time after the W32Time service stops.KB951618 - A black screen issue occurs on a windows xp based computer that has Onekey Recovery 5.0 installed when you upgrade the operating system.KB951624 - A 30-second delay occurs during the initialization of some network-based applications when Windows XP starts.KB951709 - Event ID 26 when you attach two IDE ATA/ATAPI devices as master and subordinate IDE devices on a Windows XP-based computer.KB951748 - Security update for DNS in Windows XP.KB951978 - Script output is not displayed as expected when you run VBScript or JScript scripts in Windows XP Service Pack 3.KB952004 - Security update for MSDTC Transaction Facility.KB952020 - Error message when you try to open a clear-text signed message in Outlook 2007: "The necessary security algorithm is not supported".KB952079 - You cannot use the Backup Utility to restore certain EFS-encrypted files on a Windows XP-based computer and data corruption occurs.KB952206 - A printer-driver upgrade operation fails on printer clients that are running Server 2003 or Win XP when multiple printer queues are upgraded at the same time.KB952287 - An application that uses the ADO interface may malfunction, or data loss may occur when the application connects to SQL Server.KB952825 - IEEE 1394-compliant storage devices that are connected to an OHCI host controller are not displayed on a Windows XP-based computer.KB952954 - Vulnerabilities in Microsoft Windows Image Color Management could allow remote code execution.KB953028 - An application experiences an access violation and then crashes if the computer has more than four cores or more than four logical processors.KB953155 - Vulnerability in Windows Internet Printing service could allow remote code execution.KB953609 - Error when you try to add a wifi network to a Win XP-based computer that has KB917021 applied: "At least one of your changes was not applied successfully...".KB953761 - Some DHCP Options are not recognized on a Windows XP SP3-based client computer when the DHCP server offer includes option 43.KB954232 - The On-Screen Keyboard behavior on a Windows XP-based computer does not mimic the physical keyboard behavior in certain scenarios.KB954430 - Security update for XML Core Services 4.0.KB954434 - A multiprocessor computer that is running a Windows XP stops responding on a black screen after you resume the computer from hibernation.KB954459 - Security update for XML Core Services 6.0.KB954708 - An update to add support for the serialization of complex Extensible Metadata Platform (XMP) data types in the Windows Imaging Component.KB954920 - When an application requests a result set, "40242"/"40205" error when ODBC driver for SQL Server is used, or "40234" error when the SQL OLE DB provider is used.KB955069 - Security update for XML Core Services 3.0.KB955109 - Error message when you run an application that uses the Application Desktop Toolbar (AppBar) component: “0xC0000005 (Access Violation)”.KB955576 - TAPI-based applications stop responding, and you cannot disconnect telephone calls on a Windows XP-based telephony server.KB955704 - Support for the exFAT file system format.KB955830 - When you connect to a Win XP pc by using a RDP connection, the pc may be not able to automatically enter the Sleep mode again after you log off the computer.KB955988 - The Win32_Environment WMI class does not return the value of the PATH environment variable if the variable consists of more than 1,024 characters.KB956072 - Windows XP-based terminal server does not allow RDP connections whose encryption level is set to Low.KB956572 - Update for Windows Service Isolation.KB956625 - After you run Internet Explorer 7 for a long time on a computer that is running Windows XP, Internet Explorer becomes unstable or crashes.KB956744 - Vulnerabilities in Remote Desktop Connection Could Allow Remote Code Execution.KB956802 - Vulnerabilities in GDI could allow remote code execution.KB956803 - Vulnerability in the Microsoft Anillary Function driver could allow elevation of privilege.KB956844 - Vulnerability in DHTML Editing Component ActiveX Control Could Allow Remote Code Execution.KB957097 - Vulnerability in SMB could allow remote code execution.KB957502 - Error message when you try to open some MMC 3.0 snap-ins in a localized version of Windows XP Service Pack 3.KB958244 - The system may stop responding when you restart a Windows XP-based multicore computer.KB958644 - Vulnerability in Server service could allow remote code execution.KB958687 - Vulnerability in SMB could allow remote code execution.KB958869 - Security update for GDI+.KB959252 - Error message when you switch the operating system from a dual monitor setting to a single monitor setting: "Stop 0x0000008E".KB959426 - Gecombineerde dreigingen kunnen door een probleem in SearchPath leiden tot uitbreiding van bevoegdheden.KB960803 - Beveiligingsproblemen in Windows HTTP Services kunnen leiden tot uitvoering van externe code.KB960859 - Vulnerability in Telnet Could Allow Remote Code Execution.KB961118 - All the PCL inbox printer drivers become unsigned after you install the Microsoft .NET Framework 3.5 Service Pack 1.KB961371 - Vulnerabilities in the Embedded OpenType Font Engine could allow remote code execution.KB961501 - Vulnerabilities in the Windows Print Spooler could allow remote code execution.KB961503 - You cannot input characters as expected by using a non-English Input Method Editor in Windows Live Messenger.KB967048 - Error message on a Windows XP-based computer that has a USB card reader: "Stop 0x000000D1"KB968389 - Extended Protection for AuthenticationKB968537 - Vulnerabilities in Windows Kernel could allow remote code execution.KB968764 - Streaming USB 1.1 devices that are connected to an external USB 2.0 hub behave incorrectly on a Windows XP-based computer.KB968816 - Vulnerabilities in Windows Media Format Could Allow Remote Code Execution.KB969059 - Vulnerability in Indexing Service could allow remote code execution.KB969238 - A data transfer is corrupted when you transfer data from or to a USB device on a computer that is running Windows XP.KB970238 - Vulnerability in RPC Could Allow Elevation of Privilege.KB970553 - Error message when you query Win32_Product class after you install applications by using MSI 4.5 with "Per-User" option in Windows XP.KB970653 - August 2009 cumulative time zone update for Microsoft Windows operating systems.KB971029 - Update to the AutoPlay functionality in Windows.KB971314 - All PCL inbox printer drivers become unsigned after you install .NET Framework 3.5 SP1 or the XPS Essentials Pack in WinXP.KB971486 - Vulnerabilities in Windows Kernel Could Allow Elevation of Privilege.KB971557 - Vulnerabilities in Windows Media File Processing Could Allow Remote Code Execution.KB971633 - Vulnerabilities in Microsoft DirectShow Could Allow Remote Code Execution.KB971657 - Vulnerability in Workstation Service Could Allow Elevation of Privilege.KB971961 - Vulnerability in JScript Scripting Engines could allow remote code execution.KB972422 - A WinXP pc stops responding at the "Windows is loading your profile" screen when you connect to the computer by using an RDP connection.KB972423 - An optional update is available to update the Daylight Saving Time for Bangladesh for the year 2009.KB972435 - Slow performance when you try to open a redirected drive on a remote computer through a Terminal Services session.KB972878 - The "Guaranteed service type" Group Policy setting returns to the default value after you restart a client computer that is running Windows XP.KB973296 - After you upload encrypted files from a Windows XP, Vista or Server 2008 pc, to a WebDAV share, the files remain encrypted.KB973354 - Vulnerabilities in Microsoft Active Template Library (ATL) Could Allow Remote Code Execution (Microsoft Outlook Express 6).KB973502 - The size of the Ntds.dit file becomes larger on one or more DC's that are running Server 2003 or 2008 after you enable the credential roaming feature for the domain.KB973507 - Vulnerabilities in Microsoft Active Template Library (ATL) Could Allow Remote Code Execution (Windows ATL Component).KB973525 - Cumulatieve beveiligingsupdate voor ActiveX Killbits voor Windows XP.KB973624 - After you use a smart card to log on to a computer that is running Windows XP, Digest authentication fails.KB973815 - Vulnerabilities in Microsoft Active Template Library (ATL) Could Allow Remote Code Execution (Microsoft MSWebDVD ActiveX Control).KB973869 - Vulnerabilities in Microsoft Active Template Library (ATL) Could Allow Remote Code Execution (DHTML Editing Component ActiveX Control).KB974112 - Vulnerability in Windows Media Player could allow remote code execution.KB974455 - Cumulatieve beveiligingsupdate voor Internet Explorer 6.KB974571 - Vulnerabilities in CryptoAPI could allow spoofing.KB975025 - Vulnerabilities in Windows Media Runtime Could Allow Remote Code Execution.KB975467 - Vulnerability in the Local Security Authority Subsystem Service could allow denial of service.Alle Internet Explorer 6 Updates zijn inbegrepenAdobe Flash Player 10.0.32.18 ActiveXAdobe Flash Player 10.0.32.18 Plugin (Mozilla)DirectX 9.0c Runtimes Augustus 2009GDI+ Detection Tool (KB873374)Microsoft European Union Expansion Font Update 1.2Microsoft Silverlight v3.0.40818.0Microsoft Update 7.4.7600.226msxml2msxml3msxml4QFEcheck v6.2.29.0Root Certificate Update - (KB931125)Windows Feature Pack for Storage 1.0 - Image Mastering API v2.0 (IMAPIv2.0) Update for Blu-Ray Media (KB952011) Windows Feature Pack for Storage 1.0 - ICCD Smart Card Driver (KB952013) Windows Genuine Advantage v1.9.40.0Windows Media Player 11 (v11.00.5721.5268)KB928788 - Windows Media Player 11 may not work correctly when you use the Media Sharing feature to stream Windows Media format video content across a home network.KB929399 - You repeatedly receive a message to install update 929399 on a computer that is running Windows Vista or Windows XP.KB929773 - You hear an unexpected noise or a problem in the audio playback when you play back a Windows Media Audio (WMA) file on certain hardware devices.KB932390 - The encoder cannot use the Windows Media Audio 9 Voice codec after you install Windows Media Player 11 on a computer that uses Windows Media Encoder 9 Series.KB933547 - Windows Media Player 11 may crash if you plug in certain flash memory devices while you use Windows Media Player in Windows XP.KB935551 - Device connection is disconnected when you synchronize lots of files between Windows Media Player 11 and a Windows Mobile device.KB935552 - Windows Media Player 11 may stop responding when you transfer media to a device that uses the Media Transfer Protocol and then you cancel the transfer process.KB939209 - When you use an application to play DRM-protected video content in Windows XP, the application may fail.KB939683 - Update for Windows Media Player 11 for Windows XP.KB941569 - Vulnerability in Windows Media file format could allow remote code execution.KB944882 - The memory for an application increases for each file that you transfer when you transfer media from a pc that is running Vista or XP to a portable device.KB952069 - Vulnerabilities in Windows Media Components Could Allow Remote Code Execution (959807).KB954069 - Windows Media Encoder 9 crashes when you switch the input and output viewers and change resources repeatedly.KB954154 - Vulnerability in Windows Media Player could allow remote code execution.KB954155 - Vulnerabilities in Windows Media Runtime Could Allow Remote Code Execution.KB970775 - The seek slider sticks at the beginning of the seek-bar on the Windows Media Player control panel when you play a media file that is encoded with GSM codec.kb973442 - An application that uses the WMV codec cannot play back content that is encoded in the MBR format.KB973815 - Vulnerabilities in Microsoft Active Template Library (ATL) Could Allow Remote Code Execution.---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Opmerkingen:[*]Deze pack is enkel bedoeld voor de Nedelandse versie van Windows XP (Home/Pro).[*]Deployment via RIS methode geeft met dit UpdatePack diverse problemen (oorzaak: onbekend) (update: RVMintegrator gebruikers hebben hier alleen last van!).[*]Nieuw aangekoppelde USB invoerapparaten geven een Wizard Hardware Toevoegen popup. (update: alleen nLite gebruikers kunnen hier last van hebben).[*]Het is bekend dat %windir%\setuperr.log enkele meldingen bevat over sommige bestanden.Dit gaat dan om systeembestanden die je bijvoorbeeld door addons laat aanpassen. Voorbeeld: Xpize, uxtheme, Internet Explorer 7/8.[*]Commandprompt > qfecheck.exe -v geeft meer informatie over de ge Edited October 22, 200915 yr by Stefhan
July 30, 200915 yr Author Changelog XP UpdatePack Post-SP3 x86 NLD v2.2.8-Toegevoegd: KB955830-v2-Toegevoegd: KB974455 (vervangt KB972260)-Toegevoegd: KB958869 (vervangt KB938464)-Toegevoegd: KB969059-Toegevoegd: KB971486-Toegevoegd: KB972422-Toegevoegd: KB973525 (vervangt KB973346)-Toegevoegd: KB974112 (vervangt KB954600)-Toegevoegd: KB974571-Toegevoegd: KB975025-Toegevoegd: KB975467-Geupdate: Malicious Software Removal Tool 3.0 (Stubbed)Changelog Mediaplayer 11 (2.2.8)--Toegevoegd: KB954155Changelog XP UpdatePack Post-SP3 x86 NLD v2.2.7KB955704 (vervangt KB967715), KB961371-v2 (vervangt KB961371), KB970553, KB971029, KB971314, KB972435, KB972878, KB973296 (vervangt KB945015), KB973502, KB973624, Root Certificates september 2009, DirectX runtime augustus 2009, KB973442_wm11 (vervangt KB954067_WM11)Changelog XP UpdatePack Post-SP3 x86 NLD v2.2.6KB956844, KB968816, KB971961, MU/WU v7.4.7600.226, Microsoft Silverlight 3.0.40818.0, Malicious Software Removal Tool 2.14 (Stubbed) Edited October 22, 200915 yr by Stefhan
September 25, 200915 yr Author Geupdate naar v2.2.7!Misschien moet ik maar wat bugs in het updatepack stoppen om een hier een goede discussie te starten :type: . Edited September 25, 200915 yr by Stefhan
October 22, 200915 yr Misschien moet ik maar wat bugs in het updatepack stoppen om een hier een goede discussie te starten :type: .ROFL! bedankt weer voor de update :thumbsup_anim:
