Posted July 30, 200915 yr Tera Copy 2.12TeraCopy is a compact program designed to copy and move files at the maximum possible speed, providing the user a lot of features: * Copy files faster. TeraCopy uses dynamically adjusted buffers to reduce seek times. Asynchronous copy speeds up file transfer between two physical hard drives. * Pause and resume file transfers. Pause copy process at any time to free up system resources and continue with a single click. * Error recovery. In case of copy error, TeraCopy will try several times and in the worse case just skips the file, not terminating the entire transfer. * Interactive file list. TeraCopy shows failed file transfers and lets you fix the problem and recopy only problem files. * Shell integration. TeraCopy can completely replace Explorer copy and move functions, allowing you work with files as usual. * Full Unicode support. * Windows 7 x64 support.This the Free For home user editionDownloadMD5:A642E1408DB577CD4016B0476EF8DF23ChangeLog20-1-2010Updated To Tera Copy 2.1231-7Initial Addon Release Edited January 20, 201015 yr by DaRk MaDnEsS
August 13, 200915 yr THX for your work :thumbsup_anim: But I wondered if its possbile that your TeraCopy-addon sets these 3 options automatically:This would be perfect, because at the first Windows-start I will have to set these options manually to replace the Windows-copy.Best regards and thanks a lotcool400 :icon_cool: Edited August 13, 200915 yr by cool400
August 13, 200915 yr THX for your work :thumbsup_anim: But I wondered if its possbile that your TeraCopy-addon sets these 3 options automatically:This would be perfect, because at the first Windows-start I will have to set these options manually to replace the Windows-copy.Best regards and thanks a lotcool400 :icon_cool:hmm that is wired i already set them to work and there is already commands for that i gonna check for them but i'm afraid not now but today i will see and tell you
September 8, 200915 yr hmm that is wired i already set them to work and there is already commands for that i gonna check for them but i'm afraid not now but today i will see and tell youHi DaRk,have you figured out if your addon works for you how you wrote? Or do have any idea for me what went wrong?Best regardscool400 :icon_cool: Edited September 8, 200915 yr by cool400
September 8, 200915 yr well i made a fix for the associatebut i didn't have a time for testing it if you have time can you test this infDM_TC.in_
January 21, 201015 yr Updated To 2.12thank you DaRk MaDnEsS!edit: i likewise encounter the same avast/avg prompt there's a virus ... although, you've already shown in another thread this is false positive ... just wondering if there's an existing work-around here ... atm, i'm always turning off my free anti-virus ... thanks for the work just the same Edited January 21, 201015 yr by kiki burgh
