W7T
wazer
I simply dont get it how to manage your wim files.. I cant find them in sources.. The program wont let me see them.. If i wanted to capture it then i need to select a folder to saved the wim image and after that i need to find it.. Its there guide for the program. Im truly sorry if this is bad english.. Im frustrated ! ;)) Hope theres someone that can help..
Thanks.
Link to comment
Share on other sites
I simply dont get it how to manage your wim files.. I cant find them in sources.. The program wont let me see them.. If i wanted to capture it then i need to select a folder to saved the wim image and after that i need to find it.. Its there guide for the program. Im truly sorry if this is bad english.. Im frustrated ! ;) ) Hope theres someone that can help..
Thanks.
Post a screenshot where problem arises with exact error code or details.
Link to comment
