Posted August 8, 200915 yr uTorrent 1.8.4 Build 16688275 KB98c036180ae0a543d7c9916642035007 uTorrent 2.0 Beta Build 16546294 KB9476eb03963830952e3fa068e1f7cb88DescriptionWhat Is µTorrent?Micro-Sized Yet Feature FilledµTorrent is the world's most popular BitTorrent client. Most of the features present in other BitTorrent clients are present in µTorrent, including bandwidth prioritization, scheduling, RSS auto-downloading and Mainline DHT (compatible with BitComet). Additionally, µTorrent supports the Protocol Encryption joint specification (compatible with Azureus 2.4.0.0 and above, BitComet 0.63 and above) and peer exchange.Resource-FriendlyµTorrent was written with efficiency in mind. Unlike many torrent clients, it does not hog valuable system resources - typically using less than 6MB of memory, allowing you to use the computer as if it weren't there at all. Additionally, the program itself is contained within a single executable less than 220 KB in size.Skinnable and LocalizedVarious icon, toolbar graphic and status icon replacements are available, and creating your own is very simple. µTorrent also has support for localization, and with a language file present, will automatically switch to your system language. If your language isn't available, you can easily add your own, or edit other existing translations to improve them!Actively Developed and ImprovedThe development team puts in a lot of time working on features and making things more user-friendly. Releases only come out when they're ready, with no schedule pressures, so the few bugs that appear are quickly addressed and fixed. Edited October 13, 200915 yr by Jatin Beniwal
September 8, 200915 yr Hey, sorry but i've got a problem here and i think you made a small mistake... lolWhen i try to install it it says i'm using build 7600 but it wants build 16010?? lolYou put the build of utorrent in that bit... lol
September 9, 200915 yr Author Hey, sorry but i've got a problem here and i think you made a small mistake... lolWhen i try to install it it says i'm using build 7600 but it wants build 16010?? lolYou put the build of utorrent in that bit... lolThanks! Fixed and Updated to 1.8.4
September 18, 200915 yr new utorrent 1.8.4 build 16442will there be a updated addon ?-- 2009-09-10: Version 1.8.4 (build 16442)- Fix: Potential crashes with magnet links-- 2009-09-04: Version 1.8.4 (build 16381)- Change: Disable Ask for unsupported 64-bit Windows- Fix: Buffer overrun vulnerability- Change: Conservative network locking in installer-- 2009-08-28: Version 1.8.4 (build 16301)- Fix: Installer crash after download- Fix: Crash when peers disconnect from a magnet-link torrent right as we received the metadata-- 2009-08-27: Version 1.8.4 (build 16286)- Fix: Fixed negative allocation in RequestChunks() for web seeds- Fix: Fix startup race condition between network and disk I/O thread- Fix: installer with UAC- Fix: Crashes when removing labels- Fix: selection of labels over 256 characters in length-- 2009-08-12: Version 1.8.4 (build 16150)- Feature: Enabled magnet bundles.- Change: run the 64 bit version of explorer when running as a 32 bit app in a 64 bit windows os.- Change: disable toolbar offers for Wine installs- Change: uninstaller is added to all user profiles- Fix: crash when assigning new label to torrents from RSS- Change: Incomplete downloads sort after completed downloads if sorting by "Completed On"- Fix: maintain category list selection on update for some edge cases- Change: if selected, install start menu and desktop shortcuts to all users instead of only current user- Fix: buffer overrun vulnerability in create torrent dialog- Fix: Check at startup for incompatible versions of NVIDIA nForce firewal
September 18, 200915 yr Author new utorrent 1.8.4 build 16442will there be a updated addon ?-- 2009-09-10: Version 1.8.4 (build 16442)- Fix: Potential crashes with magnet links-- 2009-09-04: Version 1.8.4 (build 16381)- Change: Disable Ask for unsupported 64-bit Windows- Fix: Buffer overrun vulnerability- Change: Conservative network locking in installer-- 2009-08-28: Version 1.8.4 (build 16301)- Fix: Installer crash after download- Fix: Crash when peers disconnect from a magnet-link torrent right as we received the metadata-- 2009-08-27: Version 1.8.4 (build 16286)- Fix: Fixed negative allocation in RequestChunks() for web seeds- Fix: Fix startup race condition between network and disk I/O thread- Fix: installer with UAC- Fix: Crashes when removing labels- Fix: selection of labels over 256 characters in length-- 2009-08-12: Version 1.8.4 (build 16150)- Feature: Enabled magnet bundles.- Change: run the 64 bit version of explorer when running as a 32 bit app in a 64 bit windows os.- Change: disable toolbar offers for Wine installs- Change: uninstaller is added to all user profiles- Fix: crash when assigning new label to torrents from RSS- Change: Incomplete downloads sort after completed downloads if sorting by "Completed On"- Fix: maintain category list selection on update for some edge cases- Change: if selected, install start menu and desktop shortcuts to all users instead of only current user- Fix: buffer overrun vulnerability in create torrent dialog- Fix: Check at startup for incompatible versions of NVIDIA nForce firewalI think its better to Update it to next major release i.e. utorrent 2.0. Its releases in a few days instead of updating 1.8.4 in every few days. If u like u can simply update ur addon by replacing utorrent.exe with new build and re-compress it .
September 19, 200915 yr Author updated uTorrent 1.8.4 to Build 16442 and uploaded uTorrent 2.0 Beta Build 16546 Edited September 19, 200915 yr by Jatin Beniwal
September 21, 200915 yr what should the file type be ? as there is no .cab or .7z or .exe at the end of the addons..all i got when downloaded is uTorrent 2.0.WA&uTorrent1.8.4.WAive never heard of a .WA file before Edited September 21, 200915 yr by dude-uk
September 21, 200915 yr what should the file type be ? as there is no .cab or .7z or .exe at the end of the addons..all i got when downloaded is uTorrent 2.0.WA&uTorrent1.8.4.WAive never heard of a .WA file beforeYou can use the WA Installer to install them on a live system or use W7T to install (integrate) them into a Windows 7 ISO. Edited September 22, 200915 yr by Jatin Beniwal
October 13, 200915 yr Author updated uTorrent 1.8.4 to Build 16688Change Log- Fix: fixed potential crash in WSARecv and WSASend- Fix: fixed piece availibility issue introduced in previous build- Change: Balance CDNs to download updates- Fix: Fixes bug where magnet links wouldn't work if PEX was disabled- Fix: potential crash in network code- Fix: More crashes when using magnet links
August 10, 201113 yr A new version of Utorrent 3.0 is released is released.http://download.utorrent.com/beta/utorrent-3.0-latest.x64.exehttp://download.utorrent.com/beta/utorrent-3.0-latest.exe
September 3, 20168 yr So many dead topics in this forums nowadays.... Feels like visiting a ghostly forum.... Back in 2013 this forum was so flourishing & active.... Well, nowadays people's (even mine) schedule is so tightly packed... Wish those good ol' days were back in this world... Oh god! Edited September 3, 20168 yr by niTe_RiDeR_Pr0
September 3, 20168 yr 5 hours ago, niTe_RiDeR_Pr0 said: So many dead topics in this forums nowadays.... Feels like visiting a ghostly forum.... Back in 2013 this forum was so flourishing & active.... Well, nowadays people's (even mine) schedule is so tightly packed... Wish those good ol' days were back in this world... Oh god! Yeah, social networks are more and more popular, although I would call myself and old fashion. I still like the forums more and I am also not using social networks
