arsenalz Posted August 13, 2009 Posted August 13, 2009 [sVCPACK] Microangelo Toolset 6.10.0008Add-on for nLite or RVM Integrator.Microangelo Toolset 6 includes an icon editor that creates and edits icons for all Windows platforms.Its four integrated components work together to create, edit, access, find, extract, filter, and manipulate icons and the images they contain.Toolset provides a solid foundation of icon tools used by today's (and tomorrow's) icon masters.- Multilingual.- Four tools: Studio, Explorer, Librarian and Animator.- Create and edit icons in all sizes and formats with Toolset's icon editor.- Make icons from PSD, PNG, JPG, or BMP files.- Edit icons inside ICO, ICL, EXE, DLL, and other program files.- Change program icons using a Windows interface or the command line.- Search and extract icons from icon resources, libraries and program files.- Make animated cursors with Animator, Toolset's animated cursor editor.- Microangelo Toolset 6 supports Windows 7, Windows Vista, Windows XP and Windows 2000.- 32bit only! (Standard Win7/Vista 64-bit versions: on website).Homepage: http://www.microangelo.us/Download: http://www.4shared.com/file/124852709/87ddfc8a/Addon_Microangelo_Toolset_6100008.htmlMD5: caf8d0c101b059c8f4f56f6d1c6a1890Size: 4.34 Mb Quote
