Posted February 8, 200718 yr Useless, but funny.UberIcon creates a more customizable atmosphere on your desktop by extending Windows to perform new effects when you launch your icons and folders. The effects are plugin-based to give you control over the look and feel. The name translates to "OverIcon" which will begin to make sense from the moment you see your first icon fly towards you. Features:Extrememly efficientPlugin-based for complete customizationIntegrates with your Desktop, Explorer and most softwareUnicode compliantSimple plugin SDK for creating new effectsIncluded Plugins: iZoomiBounceFlatOutSupports many languages and can easily be translatedAnd best of all...its FREENew Plugin included.To install a new plugin follow these simple step:Move the folder containing "fx.dll" into your UberIcon\\Plugins directory.The path should be something like this:C:\\Program Files\\UberIcon\\PluginsLaunch UberIcon and right-click on the icon in your system tray. Select your new plugin from the "Plugins" menu.Download Edited June 6, 200717 yr by N1K
June 6, 200717 yr Hi, I just went to download and the link appears to be down It sounds like a bit of fun though.
