What is it?
RocketDock is a smoothly animated, alpha blended application launcher.
It provides a nice clean interface to drop shortcuts on for easy access and organization.
With each item completely customizable there is no end to what you can add and launch from the dock.
Now with added Taskbar support your minimized windows can appear as icons on the dock. This allows for better productivity and accessibility.
Features:
* Minimize windows to the dock
* Real-time window previews in Vista
* Running application indicators
* Simple drag-n-drop interface
* Multi-monitor support
* Supports alpha-blended PNG and ICO icons
* Icons zoom and transition smoothly
* Auto-hide and Popup on mouse over
* Positioning and layering options
* Fully customizable
* Completely Portable
* ObjectDock Docklet support
* Compatible with MobyDock, ObjectDock, RK Launcher, and Y'z Dock skins
* Runs great on slower computers
* Unicode compliant
* Supports many languages and can easily be translated
* A friendly user base :)
* And best of all... its FREE!!!
Non startup Version
tabdownload.png [Windows Live SkyDrive] No Startup on boot.
size.png5.97MB (6,262,238 bytes)
post-4451-1205780671.png 7137C6DB2DDA2DD4DC4F0E3E520829DF
Startup Verison
size.png5.97MB (6,268,173 bytes)
post-4451-1205780671.png ABA52167822B04E8F2513D2068231D10
Version: 1.3.5
Platform: x86 and x64
Addon Release Date: August 16 2009
Uninstallable: Yes
Edited by snakecracker
Added startup at boot Version.
Might remove the non startup version....?
