Posted August 18, 200915 yr OK, I have gotten back into gaming now. My issue is, Is just installed COD 5 and I haven't even played it but my RAM usage is at 88%. I had this issue after playing COD 4. the only way I could get the RAM usage to normal is a restart.Does anyone know what is going on? Or how I can get it back to normal? It does not show up in Task Manager so I can end process there and it is not a running app.THANKS
August 18, 200915 yr well it seems that PunkBuster is having an issue in COD 4that what i read seems that update should fix that issue with it
August 18, 200915 yr Author well it seems that PunkBuster is having an issue in COD 4that what i read seems that update should fix that issue with itI have no ideal what PunkBuster is so I installed without it.
August 18, 200915 yr I have the same issues on my Windows 7 x64.Couple of days ago, my memory consumption was at 90%, with all of the apps closed, I couldn't start anything without getting low resources error.Seems that a lot of applications which are not updated for win7, have some kind of memory leak once used with it.
August 18, 200915 yr Author I have the same issues on my Windows 7 x64.Couple of days ago, my memory consumption was at 90%, with all of the apps closed, I couldn't start anything without getting low resources error.Seems that a lot of applications which are not updated for win7, have some kind of memory leak once used with it.Thanks N1K, maybe it is a Win7 issue
August 18, 200915 yr I've played a few games and have had no problems....?It will be a shame if there is an issue with the release!Would give Win7 a bad name!
August 19, 200915 yr Author PunkBuster is basically something that prevents hacks/exploits/cheatersThanks, I looked it up after I replied the last time.
August 20, 200915 yr Its is definatly Punkbuster, It does not like W7 (as of now, I dont know about any of the newer builds). Edited August 20, 200915 yr by x-shadow-x
