Posted (edited)
I Recently downloaded some Vista screensavers for my Windows XP and some came with a text document tiltled "settingsREAD" so I read it and need help on how to go about it :g:. Here is what is said:
This one is for the Bubbles Screensaver.
Path: HKEY_CURRENT_USER\Software\Microsoft\Windows\
CurrentVersion\Screensavers\Bubbles
- SpanMultiMon [DWORD] 0/1
Enables/disables multiple monitor spanning support.
Enable this to have one set of bubbles travel across
screens. Disable this to have bubbles on each (and possibly
different configurations)
- SphereDensity [DWORD] int
Self explainatory
- Radius [DWORD] int
Self explainatory
- TurbulenceNumOctaves [DWORD] int
Self explainatory
- TurbulenceSpeed [DWORD] int
Self explainatory
- TurbulenceForce [DWORD] int
Self explainatory
- ShowBubbles [DWORD] 0/1
Enable/Disable showing of background for bubbles
- MaterialGlass [DWORD] 0/1
Enable/Disable translucent bubble effects
- ShowShadows [DWORD] 0/1
Self explainatory
- AllScreensSame [DWORD] 0/1
Enable/Disable the sharing of bubbles configuration across
screens (use global settings).
NOTE: To specify settings for different screens,
create a key (e.g. "SCREEN 1") and put your settings (above)
in this folder. Global settings are put directly in the
parent key.
Edited by Rye65
