Posted September 7, 200915 yr Hey guys, i need some help. I want to automatically install and change the default theme in windows 7 as well as the default cursors too, is there a way to do this via a reg file?
September 7, 200915 yr Why not use autounattend.xml?You can add your custom cursor scheme in your .theme file
September 7, 200915 yr If i monitoring registry and changing cursors i get this:You must delete this\S-1-5-21-3141826708-2193451549-4040042613-1001after changing and exporting registry entries. Because this line is different at others PC
September 8, 200915 yr Author thanx guys for the reply, i want to install via nsis installer the cursors, by opying them to c:windows\cursors and the add a reg file to make them default, the same i want to do with the theme file.
