WA Installer 2.7.0.0
Hi every one
Today i present to you a nice tool
allow you to install WA files on a running pc
better for testing than doing a VM to test your files
just report and it will be fixed
the tools assign it self to WA extension
Picture when you click on a files
now to download
Download
MD5:DB3E82FF6BF78AF46E8C6E978821E5F1
enjoy hope you like the tool
Thx For snakecracker for testing the tool
and helping me tracing some bugs down
Quote
To Translate
Translate this Lines
[LangInFo]
Lang=English
[installer]
UpperLabel=Install WA Installer on your Computer
SecondLabel=WA Installer Will be Installed On Your computer&If you want to Continue Press Install
[buttons]
OkButton=OK
UniButton=Uninstall
CanButton=Cancel
FinButton=Finish
IgnoreButton=Ignore
InstallButton=Install
[Title]
Choose=Choose Addons you want to install
Error=Error
Loading=Windows 7 Toolkit Addon Installer
Installer=WA Installer
Uninstaller=WA Uninstaller
Install=Installing
[Error]
WrongParametrs=Wrong Parametrs&Check the Paramerts from This List&"/Uninstall" : To Uninstall this Tool&"/S" : Install the Program Without the Yes/No Window&"/Path:" :The Files Path to to WA File
NoTasks=No Tasks.txt File Detected.
Arch=Your OS Arch is&And the Program Requires
Build=Your OS Build is&And the Program Requires
[Label]
Load=Loading Info
Success=Got Installed successfully
[install]
Ques=Do you Want To Install
Ver=Version
By=By
[uninstaller]
UpperLabel=Remove WA Installer From your Computer
SecondLabel=WA Installer Will be uninstalled From Your computer&If you want to Continue Press Uninstall
UniLabel=Uninstalling WA Installer
Uninstalled=WA Installer Got UnInstalled successfully
Save it with the extension .lang
then put it into "%programfiles%\WAInstaller\Lang"
,add it's name in Option.ini
and upload it to integrate it
WA Installer ChangeLog
2.7.0.0. (14-10)
All 64 bit problems should be Fixed Now
2.6.0.0 (8-10)
In case added the Case sensitive fix for the Arc , Website etc words
now since there is no ! beside the build if the build didn't match and the build is higher it would pass
Added Website link
Fixed an issue in the code with 64 bit ( would be obvious if you using an addon that sends to the system32) << most of the times happens there
Added German Language
2.5.0.0(25-9)
New Modified build and arc reader (fixed case senstive problems)
New Ignore Button (To Ignore Build or Arc not matching)
New installer (you can choose language from it)
New shortcut to run the program from it
Added Progress Bar When Installing Addons
Added Arc (Any,N/A) support with (case senstive disable)
2.1.0.0(17-9)
Fixed 64 Bit issue with case sestive problem
Minor bugs fixed
V2(12-9)
1-ReWrote Tasks.txt Reader
2-New Uninstaller Look
3-New Parameters /S for Silent /Path: File Path /Uninstall to Uninstall
4-Multi Language Support
5-Fixed Program Compatibility about program might not be installed correctly
6-One Setup File for both 32-64 bit
WA Installer 3 Beta
V 3.0.6.0
This is beta so i won't remove the old tool until this gets done
Download
MD5:4869704db6df2698223c06e1eb3b5841
This got a Gui but most of old Functions Before 3 are gone
i will try to work on it right now I'm just going for tracking down bugs
so when it gets free of bugs then i will work on adding functions
WA Command Line 0.1
This version is made especially for the cmd users
it helps them in the silent install etc..
here is a Screen Shot
Download Both x64 and x86
with 7za.exe
Side Effects
7za extraction is not hidden
MD5:5556FD12DF1CBBD3C9EF937F162B9113
WA CMD ChangeLog
0.1(5-3) Initial Version
  • Replies 82
  • Views 48k
I'll also add its a very good tool to use for making your own addons...
I've been testing this tool for some time now and it has helped me out alot.
Thanks Great One.
thx for your reply i hope you like it
Updated to 2.0.0.0 !
Hope you like it
At least i don't have to make a WA Installer now :P Good work :D
thx lego :blush:
well i have seen a lot of people of people wanted it
and you have been busy so i said lets give a hand since we can do it
and thx for your awesome tool
Maybe integrate this tool into Windows 7 Toolkit?Nice work. :thumbsup_anim:
about integrating the tool if lego wants it's no problem for me
he can put it in the installer
but i think it should be kept separated
and thx for your replay
Hello and thank you for this wonderful installer tool! However, I am encountering a problem. Whenever there is a specific choice of x86 or x64 add-ons, I get an error that says 'Your OS arch is x64 and the program requires x64'...I am using the 64 bit Windows 7 RTM and am selecting the 64-bit add-on, so I don't understand why this error occurs, and I am not able to install the add-on after closing the error.
Any suggestions would be much appreciated and keep up the great work!
You're right there are problems on x64. 1.0.3 is fine but 2.0 isn't. I thought it was due to case sensitivity because I noticed the error was actually 'Your OS arch is x64 and the program requires X64' but I changed one of the addons to match and I still got the error.
I have told him about this he will fix asap! :)
Hello and thank you for this wonderful installer tool! However, I am encountering a problem. Whenever there is a specific choice of x86 or x64 add-ons, I get an error that says 'Your OS arch is x64 and the program requires x64'...I am using the 64 bit Windows 7 RTM and am selecting the 64-bit add-on, so I don't understand why this error occurs, and I am not able to install the add-on after closing the error.Any suggestions would be much appreciated and keep up the great work!
well yeah the tool had a lot of issue with a case senstive problem
well 2 had a lot of code changes i tired to add an early work around but it seems that it made stuff worth
so i changed some stuff in the code to fix that issue
and the problem is actually from case sensitive but there was another issue with it
that made it do that
Updated to WA Installer 2.1.0.0
well snake tried the new version
and it seems it fixed the issue
i didn't do a lot of testing this time
there would be another version soon
well finish the new installer soon
and will support language chooser
so if one made a translate upload it to me and will be added next version
Hi,
thx a lot for the updated version.
But when I start under Win7 64 I get the message: "No Tasks.txt File detected"
PRetep
this happens with which addon ?
or all addons like that ?
hmm does the program runs as admin or not
this problem might happen if you run the program from "program files"
if you did that then
reinstall the tool
and then run a WA File
i think i will release a fix if you run the tool from program files
cause it deletes the files there
reinstall the tool
oh yes. I did so! And of course, in that way it works very well!
I used the dreamScene addon, but after installing there is no dream ...maybe I should restart ...
PRetep
PRetep
well i already added plan to version 2.5.0.0
the program would have a new gui
when you click on the shortcut
it would open a screen you choose the wa file
and about the dreamscene
the tool does install it with no problems
but for some reason it doesn't work
maybe today i will read more about it
Great! Thanks a lot again ... See you later.
Pretep
PRetep
dreamSene addon needs explorer restart to show options & it works fine after restart.
Hm... But (unfortunately) not for me. After restart there is no way to use as background option with right mouse click on any *.mpg ...
PRetep
Hi,
is there already a new version 2.5?
Pretep
well it's under construction
i do that with most of my work
i post what would be there when it's out soon
but still i'm working hard on fixing the issues
reading a lot about autoit scripting language to find a new way to do the work
Updated !
Please test and report
