Guest LeGend95 Posted September 8, 2009 Posted September 8, 2009 (edited) ViGlanceViGlance 1.0.0 Buid:1194True Addon intergate with Nlite or RvmStartup at windowsSize:160.96 Kb Edited September 26, 2009 by LeGend95 Quote
dude-uk Posted September 17, 2009 Posted September 17, 2009 (edited) hi.. i know you say this is build 1.0.0but what proper build is it ? what one did u use to build your addon..changelog builds from lee-soft.com Edited September 17, 2009 by dude-uk Quote
Guest Posted September 17, 2009 Posted September 17, 2009 well this version says 1182 but it's not on the change log that is wired :confused02: Quote
v3jqv6mhl9bn Posted September 19, 2009 Posted September 19, 2009 it is the final copyBuild 1182 is not the final copy, I made one for build 1194 and posted it about the same time as you.I don't know if there is newer than 1194, but it was the latest when I last looked. Quote
Guest LeGend95 Posted September 23, 2009 Posted September 23, 2009 Build 1182 is not the final copy, I made one for build 1194 and posted it about the same time as you.I don't know if there is newer than 1194, but it was the latest when I last looked.Ok Iam sory this is not final i will make the final copy 1194 Thanx Quote
